RumRunner
Fitted new battery, bit of a faff re tight space and waggle to get front edge under rear seat lip, needed to bend the lip up a bit to squeeze it right into position twice, once for battery to go back fully and then reverse bend so weird clamp system could be reconnected (insecure battery re MoT inspection now = failure), all done and car run  for two lots of 20 mins to get rid of damp as it not been started since December last.
glad that over and done with - very cold working in the field where this was one hidden - was sunny and dry though !!
Edited by urquattro
Fitted the new Bilstein B8 rear shocks and Eibach springs with all new associated parts (apart from the bump stops)
The car now has all the parts of a B12 kit. Will give it a little test and settling in drive once rush hour has been and gone :-)
Sent from my E6853 using Tapatalk
Not that you wouldn't bolt it down, but can a tester remove the back seats to check the security ? and yes i agree its an arse trying to get the bigger battery in.
This battery you guys are struggling with, what size is it? I thought they were supposed to take a type 019 but if I'm going to have to bend stuff to get it in I'll get a smaller one.
I bought a battery from BMW and its made by Exide ( Length: 278 mm, Width: 175 mm, Height: 175 mm)
http://ows-cdn.tecdoc.net/exide/home.jsp?server=2&time=12/2/2016-12:44:48#73b7fd6597330b0a60c63e415ffd4c90
EXIDE Starter Battery PREMIUM ***
Trade numbers: 096TE
Voltage: 12 V, Battery Capacity: 72 Ah, Cold-test Current, EN: 730 A, Length: 278 mm, Width: 175 mm, Height: 175 mm, Terminal Placement: 0, Terminal Type: EN, Hold-down: B13, Cold-test Current, EN: 720 A
And they do a standard one too:
EXIDE Starter Battery EXCELL **
Trade numbers: 096SE
Voltage: 12 V, Battery Capacity: 71 Ah, Cold-test Current, EN: 670 A, Length: 278 mm, Width: 175 mm, Height: 175 mm, Terminal Placement: 0, Terminal Type: EN, Hold-down: B13
M5 battery is a very tight fit under back seat and up against front of rear seat frame, with a slip under ledge for front profile and a raised block at rear to fit inside,  this is drilled with a threaded insert for attaching the base retaining strap ( two pieces) the second piece then meet the lip of the seat frame and is secured at that point.
plus edc wiring and plugs in way as well. My garage will test the battery securing issue re any MoT, totally sure of that hence the need to do it properly.
Maybe the new the battery case is just a touch bigger than the old/original re some EU standard now, so it was grunt/groan/moan and bum in the air time for a while to manoeuvre it properly in for strap to fit - took a removal and second placement to waggle it home after the lip bending task re overall height now just touching the underside of seat base. Its important to make front edge of battery slide into the front retaining shape in floor - that was the key in my car.
needs to be a high amp/starting load to bang to 3.8 into full start mode in colder times.
Edited by urquattro
Ah an M5 specific complication then.
The battery in my 525i has spent most of the past two years flat as a pancake, I'll be upgrading to a bigger one as 68aH is a bit borderline.
my M5 has a 95ah bosch S4 badboy, needs it that big 6. Alot of engine to turn over! Its a very tight fit also
Thank you for you're help with the steering box people going to attempt it this weekend. I have just fitted this battery it was from halfords £120 it's a monster but fitted without any bending of metal at all
I have the Bosch S5 013 100ah Battery in mine (E39 M5 spec apparently) and it's a snug fit... This is also known as the 019.
Edited by Spice-Boy
Today I removed my B-pillars as the material had come loose and took it to a local car upholstery company and they were kind enough to sort them out for me :-)
More stuff done today... M5 seat belts fitted, one of the newly repaired B-pillars fitted, strut bar fitted (dunno if I'm keeping it yet though) and more rattle hunting (failed too)...
I am a very happy camper today aftger the engine not starting for close to a year.  Put a new battery in and turned over for  secs she fired and ran.  Slight ticking from the tappets other wise sounded good gives me the motivation to get the car finished. It did bring a big smile to my face to hear the engine running took it all the way up to running temps and all was good oil temp, oil pressure and voltmeter was good as was the coolant temp
So today is the start of getting the car prepped for MOT retest. My polybushes arrived from Poland (shout out to StrongFlex, super quick delivery! Only 4 days!!). So I started polybush bushing the front thrust arms, and front & rear roll bars. haven't tackled the lower control arms just yet, because my NSF one is steel, where as the OSF is aluminium, so going to sort that out soon.
Also ripped out the back seat, as I'm going to be fitting some new 60/40 lowering springs I picked up for a bargin £21!! (They were on sale).
Still got loads to do, such as rear sub-frame bushes, trailing arm bushes, fitting a new steering lock, and then change my OSR wheel bearing. The finally I'll be able to then replace the handbrake mechanisms.
Edited by BkS
520 touring panel donor dragged back to storage. Time to invest in metal shears me thinks
