RichardP
Firmware V6.02-7058 and User Guide
Hello,
@RichardP may I ask some help ?
I updated my FW to 7058 but had a lot of failed / retry while flashing...
Now I see there is newer FW here, but I'm not able to flash it anymore, no matter what I do, I have 2 laptops, one with usb to serial, and one with genuine serial, both do the same strange characters when plugged to intravee.
On the car, the intravee works fine, music, ipod, controls... just the auto close feature does not work (2003' 530i E39)
Thank you.
This is a serial port issue.  If you were not using a native serial port on one PC i’d Blame the USB adapter.
The port speed is correct for the default Intravee settings, I’m wondering if at some point the Intravee itself has have its serial port speed changed.  Try setting the speed to 64,000 and if that does not work 32,000 in the serial port settings dialog in the downloaded. Use the PC that has the native serial port if you can.
Ok I'll try this evening
I tried 9600 and did not work
Thank you
Edit : For the record I flashed with the USB to Serial adaptor first time, and after a lot of fail/retry it finally updated, but then the strange char appeared.
Since then, both laptop have the same issue, so I'll try lower value this evening.
Edited by Orphee
@RichardP and other question/info, I have a "little" bug when the radio TMC info traffic is enabled.
When a traffic info is received, the screen automatically switch to INFO menu, then at the end, or when you push INFO button, it leaves INFO traffic mode, but then the Intravee screen is frozen.
I have to use the little icon button near MODE twice to leave and go back to intravee screen.
Someone must have set the baud rate in the Intravee to a lower rate at some point, probably due to a dodgy USB serial adapter. I can’t remember off the top of my head how to change it back to the default!  I’ll look it up and post it here later.
Edited by RichardP
Not really a big deal as I won't connect it quite often...
So I tried again the "auto close" window feature, and no matter what I do, it simply does not work at all. No reaction.
Tried E38/E39 type and E39 Late, same behavior.
To change the Intravee baud rate (and DO NOT DO THIS UNLESS YOU HAVE TO!!!)
Enter the boot loader with the 'boot' command.
Enter programming mode with the 'p' command.
Set the new baud rate with the 'B xx' command where XX is :
01 = 1200 baud
02 = 9600 baud
03 = 38400 baud
04 = 57600 baud
05 = 115200 baud
Exit programming mode with the 'e' command
Reboot the Intravee with the 'b' command.
You will now have to change the downloader serial port rate to match the rate set above, otherwise you'll just get garbage.
You will need to have comfort closing enabled as an option for this to work.  The comfort closing option will instigate the window close, this option in the Intravee should enable the windows to close fully even if you release the lock button.
I don't know why it does not work then, some of the iBus codes are very specific to certain module revisions so maybe your GM has been replaced at some point for a version that's not normally in an E39.
You could try the 'cw' command followed by any of these command codes :
44 o/s/r up
45 o/s/r down
46 n/s/r up
47 n/s/r down
65 both front down
66 both rear down
87 comfort opening
88 comfort closing
for example
cw 45
should cause the off side rear window to go down.
44 o/s/r up
45 o/s/r down
46 n/s/r up
47 n/s/r down
65 both front down
66 both rear down
87 comfort opening
88 comfort closing
for example
cw 45
Hello :)
I just tried, absolutly no reaction at all with cw commands.
No error, command sent, back to "ready", but nothing happens.
01 = 1200 baud
02 = 9600 baud
03 = 38400 baud
04 = 57600 baud
05 = 115200 baud
Thank you, it worked, back to 115200 :)
And auto close does not work on the M5 too... it also has confort closing...
Edited by Orphee
In fact I can't find the module to test windows in ISTA/D...
I was able to do it on my 330 E46, but here I can't find it.
Edited by Orphee
