Leeds_finest
Silly question but...
Which recess does the coolant reservoir seal go in?
Upper:
Lower:
I originally fitted it in the lower recess, but it's not a tight fit so i thought maybe it's meant to go in the upper recess???
Ed
Edited by Leeds_finest
I just happen to have changed my rad so I just popped out to the garage and took old one apart for you. The seal in mine was in the lower recess. I have another one in a breaker car if you want me to check that too.
Tell you what though, in your second picture the seal looks loose, I can see daylight between seal and recess and I'm sure this should be a snug fit so I'm not surprised it's seeping.
Edited by jamesf
Fairly certain I've got exactly the same problem on my radiator; just haven't had the guts to take it apart yet
Sent from my GT-I9100 using Tapatalk 2
Well ever since I bought the car six thousand miles ago, it's always leaked.
However, it's not really an issue because it simply empties the reservoir but the system itself remains full, so, not a big deal, but while I was on the case I thought I would fix it.
Now that the genuine seal doesn't work properly, I may just silicon the bottle back in. I know it's a bodge, but if it works, then that's an improvement.
