Leeds_finest
E34 PAS pump whine
Mine leaks from the box, and when it gets low enough it starts groaning within a couple of seconds, can be quite alarming! My reservoir is all gungy as well, they tend to just get like that. E39 is the same.
I've got an E39 PAS pump to replace as it groans like a bastard and the steering has a habit of going very stiff now and again. I need to clean out the reservoir but I'm planning on replacing the pump anyway as they're not hard to do.
I'll check but I think they're crimped.
The crimp clips are ok when new but overtime the pipes soften up & they become loose then start leaking. The fluid also gets blown around by the viscous fan making a bit of a mess!
I've changed mine in the past for jubilees which seems to have done the trick but you need to be careful not to over-tighten them & crush or break the outlets on the reservoir.
Ok I think new clips are in order.
Just out of interest, does anyone know which pipe is the return pipe from the pump or box?
I can see one goes to the pump and one to the box, but which way does the fluid flow?
