JAM172
E28 M5.
Can anyone tell me, are the front springs on the M5 the same size as any other E28, i know they are stiffer and the ride height is an inch lower than the M535i, but are they the same in Coil diameter and wire size?
The reason i ask is that i have a 528i as well and need to give the spring company springs to work from, i have the old set of rears from the M5 and some fronts from my 528i in the shed.
RealOEM says M5 uses the same strut legs as other e28s so the spring diameter must be the same, and I'd guess they'd use the same wire size too.
Take a front wheel off the M5 and compare your loose 528 spring with the one fitted on the car.
