E39mad
Ticked over 80000 miles today
I had to travel from Cheshire to Newport South Wales today and back - a 350 mile return journey.
At absolute pleasure in the 520d and feel as fresh as a daisy having spent 6 hours in the car - the optional Comfort Seats are just brilliant.
The car averaged an amazing 54 mpg on the journey and ticked over 80000 at Ross on Wye on the way home.
Filled up near Newport as fuel is 8 pence a litre cheaper than near Macclesfield and got off the M6 at Sandbach with the computer reading 160 miles travelled and 704 miles remaining in the tank - so a 864 potential range - average speed was 60mph. Just shows what great cruisers these cars can be. No stop/start or mild hybrid on my 2010 bus!!
2 hours ago, 535i Andrew said:
Nice, it'd be interesting to know in 80,000 miles what wear and tear items (other than tyres) you've had to replace in that mileage?
Other than std servicing we have had the following in 8 years since being out of warranty:
1 set of front and rear brake pads
Replacement suspension airbags (one failed so replaced both)
Air conditioning condenser (hole in it)
New egr valve
Headlight control module
Gearbox oil service
Not bad really and cost wise certainly not worth running a warranty for.
I'm similar @ 94k, and i had mine around 50k.
  • 2x Headlight control modules
  • 1x set of front & rear pads
  • 1x set of front disc's
  • 1x rear caliper as it was sticking
  • 1x Air condenser (hole in it)
  • 1x Battery
  • 2x front lower arms
  • 1x Gearbox service
Edited by roundy
I forgot that I had a new lower suspension arm fitted last December as there was play in it. Passed the MOT but was an advisory.
My F11 is on 121k now.
From memory, in addition to regular service items it's had an air con condenser (prior to my ownership)
2 x osf torque/thrust arms
Full set of brake discs and pads
Battery
Rear shocks
Air bags
Alarm module
Coolant thermostat
Air suspension compressor, relay, and valve block.
2 x height sensors
Diff oil
Gearbox service (due again now)
Edit to add front springs replaced
Edited by Cadwell Parker
19 hours ago, 535i Andrew said:
No indeed, you've obviously not got a Friday afternoon car.
A quick tot up of costs since warranty outside of ordinary servicing shows a total spend of £1600 (parts and labour) which equates to £200 a year - cheap motoring for an express bus.
Edited by E39mad
