saji
G30 diesel filter
Hello,
My one is a G30 diesel 2017.
Wandering can I   change the diesel filter myself ? Suspecting any air bubble issue if I changed my self .
Any one had any experience ?
Thank you
1 hour ago, saji said:
Hello,
Thank you
Easy change and self bleeding. Just remove the undertray panel near the passenger front door to expose the filter, remove the electrical connection and disconnect the fuel lines along with the mounting bracket, remove and replace the filter.
Edited by Matthew Ashton
Thanks Matthew. You said self bleeding . How I can . need a machine for bleeding ?. apart from the word self bleeding everything I understood.
Sorry for asking again.
waiting for your valuable reply.
Please respond .
Thanks again
I think self-bleeding means you don't need to do anything to bleed the system. Just change the filter as it should and the car will detect the change and bleed the fuel supply system itself.
Perfect ! Even I thought like that :) But doing a first time on this G30. Thank you.
Yes, putting a new filter in place will inherently introduce air into the circuit but the car will deal with this and there is nothing for you to do.
Thanks again Mathew. I like this community :)
