r0ryb
Smith and Allen oil
Never heard of them before. They look like a very small concern, not that this is necessarily a bad thing but for the amount miles these things do between changes I believe its worth using a decent brand.
What I class as a bathtub outfit, taking a base oil and adding the correct chemicals to make it LL04 C3 spec, I'd happily use it with the same warning I give everyone, 8-10k service interval.
Smith & Allan have been in business since 1925 ;).
There ATF M1375.4 Lifeguard 6 oil was tested by an oil analysis lab & found to be the best blend compared to the ZF lifeguard 6. It was that good that it could have been from the same batch.
The ZF lifeguard 6 was found to be further from the specification than the Smith & Allan oil.
Also better than the Mannol offering & the others available.
As long as it's C3 LL04 BMW spec, use whatever you like. Just ensure you do regular changes - 10k miles max.
I give my mechanic friend money to share a barrel and this time around he's got TradeTec which has cost me significantly under £1/litre.
With the mileage my wife and I do it means we get 3 years worth of oil for both our cars for about £80-90.
