iReaper1157
Key fob only works when up close.
As above really. It’s a plug in key from an LCI with no comfort access. Only works when about 2 metres away and does seem to be getting worse. Would this be the key or the antenna?
thanks.
1 hour ago, edd_jedi said:
Could be the key battery or the diversity antenna
It’s a rechargeable battery but I’ve read that they can die off so I’ll start with that. Thanks.
7 minutes ago, It’s a Cob said:
Have you not got a spare key to try I change mine over every 3 or 4 months to give them chance recondition
No mate. Just the one.
That’s a shame your very brave if you opening the fob up and only got the one key will be squeaky bum time might be worth checking the diversity antenna out first see if you can see any problems dry joints etc
Mine was doing this, up to the point where I had to touch it on the high level brake light.
It was corrosion ect on the p.c.b for the diversity antenna.
There's a guide on here for this.
Do you happen to have a link? Searching is so hit and miss :-/
