E28525e
Fuel relay making permanent noise
Hello
My new e28 525e is starting well but the pump relay is making a permanent noise  It looks like something rotating inside thé relay
It looks like a failure Have you any idea about it ?
Edited by E28525e
Hello.
That is not the fuel pump relay, which is located next to the main relay on the side of the fuse box in the engine compartment.
I believe that this is a Revolution or Speed relay and is part of the idle control system used on early motronic systems. (1982-3).
Is it located inside the car above the glove box, near the motronic dme?
Important Information
