BarryM 294 Report post Posted April 3 I've added a switch to my setup and have plugged in 3 devices: Input 1: iPod Input 2: iPhone Input 3: DAB I've tried to name the sources as per my photo but expected to be able to re-name Net 3 as DAB (as that's what's plugged in), any idea why it seems to appear as a 4th source and is there a way to 'move' it? The naming in the light blue area also seems to conflict with the source in use, any thoughts on why this is? many thanks Barry Share this post Link to post Share on other sites
RichardP 1,190 Report post Posted April 4 (edited) The first thing to fix is the way you have the DAB connected. The DAB tuner does NOT connect to the switch, it goes between the Intravee and switch. Connect the Intravee to the ‘Output’ port and the switch output to the DAB ‘Input’ port. Not sure why you can’t rename Net 3, but get the connections sorted first. Edited April 4 by RichardP Share this post Link to post Share on other sites
BarryM 294 Report post Posted April 4 Thanks Richard, I did have it connected that way prior to getting the switch but thought putting everything through the switch was a 'tidier' solution I'll change the order, I can re-name Net 3 but then had 2x DAB devices listed on the IV switch source screen which was confusing! Will report back if I need any more help, many thanks Barry Share this post Link to post Share on other sites
