Jonhamil
Diesel Filter Heater Fault - Replaced and Still There
Hiya
I've got a 2008 E61 5 Series. Had a fault for the diesel filter heater - replaced with a second hand one on eBay. Fault is still there - saying open circuit.
I'm thinking maybe the old one went short circuit, pulled a load of amps and blew a fuse. But the large fuses in the glovebox are all ok. Does anyone know if the fuse for it is elsewhere?
Many thanks in advance,
Jonathan
Sounds like you have a fault in the wiring, if you have replaced the heater already. Check the circuit for continuity to be sure if this is the case.
Hi guys yes thanks you’re right it was a broken sensor wire at the connector
