Shaz-bmw87 0 Report post Posted March 22 (edited) Hi,My 120d 2007 bmw cranks but wont start. Did a computer error check and this appears;EKP - CED4 - 28Something to do with my electronic fuel pump module?? Does anyone know where this is located and if I replace will the car turn on? Anyone have similar issues they can help me out with please? Or is there another problem? When ignition is on i can hear the passenger side pump priming. Thanks Edited March 22 by Shaz-bmw87 Share this post Link to post Share on other sites
sanjx 180 Report post Posted March 29 Rediagnose. If you can hea the fuel pump on ignotion then it could be something else. Is the car still original or have you coded new keys or remap etc...which could have upset the DME? Is there any other errors? Try unplugging the DME and re-plugging it ensuring a good connection. Also check the earth point. It sounds moe CANBUs disabled than a physical fault and could be anything from a fuse or lose wire to a failed module or water ingress. Also just to check - the cam chain hasn't snapped has it? (everytime I see/hear 20d engine, it's first thing goes through my mind) Share this post Link to post Share on other sites
