Tompug206
Original battery from 2007 and INPA
As title says...on my 2007 LCI E61 530D I still have the original battery from 2007. This is verified by the stamp on negative terminal.
I'm starting to have a couple of warnings come up and heater blowers not on full etc.
So to rule out the IBS, is there anyway to check both the battery and IBS in INPA?
Thanks.
Not sure on the answer to your question @Keliuss or @GoNz0 should be able to help,
But if yours as you say is fourteen years old :shock: O.M.G you've had your money's worth.
These car's are known to be hard on batteries & it's generally excepted that five years is good innings.
A failing battery can cause all sorts of weird issue's.
Not sure on the answer to your question [mention=69756]Keliuss[/mention] or [mention=67254]GoNz0[/mention] should be able to help,
He's lucky it lasted that long, IBS really works!
