Steve van hool
528i won't start
12 hours ago, Captain Beaky said:
As Dunc said check the earths first but I suspect they are fine
The injectors are obviously working because the car starts so is this  a control fault? Unplug the ECU and check for corrosion on the pins and plug
Try disconnecting the fuel return and run it into a can, don't block it off its not meant to be blocked and see if it runs then
is it an auto?
Control or supply, either once running ie starter has disengaged they injectors stop firing or its not getting further fuel.
I think if the former it would stop dead almost immediately or fail to start.
As such i still think is priming the system but not switching on the pump once fired so running out of fuel.
6 hours ago, Steve van hool said:
It is a manual transmission, with working  cruise control, yes fuel will flow into a can if the fuel return pipe is disconnected
Have you tried starting the car with the return off?
Two reasons
To see if the flow stops or the return is blocked and stalls the flow
23 hours ago, Captain Beaky said:
I may have a spare, post the ID number
Hi Captain, The AFM, No is,
0280,202,025,
1272, 101.9
Ta Stephen
Edited by Steve van hool
Okay, just give me some time to remember where they are there's 3 or 4 together somewhere, they are the same as the opal monza
The two similar units are below the others are 525e and E30
0 280 202 025
1 272101.9
0 280 202 082
1 286 615.9
So I got a match, where about's are you?
