If your estate BMW 5 Series (known as a Touring or the F11 or the GT F07) has its backside on the ground one morning or you have an error message on your dash relating to a ride fault or an air suspension fault, have a look through these threads to give you an idea on what the issue is and how to resolve it.
This is a collection of just some of the threads to be found on here, not all are one here simply due to the fact, they were never resolved or closed out so there is nothing to be learned from them.
This is purely a reference thread to other posts on here and is not to be used as a discussion thread.
Failure symptoms
above thread was closed out in last post of this next thread
DIY guide to replacing the rear sir springs.
DIY Guide to replace the solenoid valve
System Behaviour
Normal behaviour
Compressor
Compressor removal (access needed to NewTIS)
Compressor Faults
Ride Height Queries
F11 Rear suspension height
F07 Ride height query
F11 ride height to high
One side failure
F07
Bump Stop issues
Disintegrating rear bump stops
Valve block
Air spring fault
Lowering of an F11
Standard or MSport Air spring differences
Tech chat on tools needed for air line.
Relay
If you want another thread adding to this, please message me and I'll reference it in here.
Edited by 535i Andrew
Guest
This topic is now closed to further replies.
