jukeboxs 0 Report post Posted December 24, 2020 I stupidly misjudged the kerb today and damaged the tyre sidewall (runflats). In your experience, would this be safe to drive on? I have tyre insurance, which should cover this under accidental damage, but doubt I'd claim if not needed. Thanks for your advice. P.S. Merry Christmas! Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted December 24, 2020 Doesn't look too deep that; IMO it's fine, but keep your eye on it Share this post Link to post Share on other sites
bmwf113.0d 852 Report post Posted December 24, 2020 I don't see why you wouldn't claim? Personally I'd not be comfortable driving on it. Not an MOT fail so just for ref: Share this post Link to post Share on other sites
FIVE-OH 181 Report post Posted December 24, 2020 No problem with that. Seen much worse go through test with similar damage. Although the rubber has come away there appears to be no cord showing so it's not illegal. If you can get hold of some vulcanising solution then I'd be inclined to bond it back into place. 1 d_a_n1979 reacted to this Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted December 24, 2020 52 minutes ago, FIVE-OH said: No problem with that. Seen much worse go through test with similar damage. Although the rubber has come away there appears to be no cord showing so it's not illegal. If you can get hold of some vulcanising solution then I'd be inclined to bond it back into place. This Contact adhesive from a puncture repair kit will do the job; done that in the past Share this post Link to post Share on other sites
stevecvo 116 Report post Posted December 24, 2020 It looks as if you just sliced the sidewall rather than gave it a hard lateral whack - which would resulted in a bulge from the weakened wall. It will probably be OK but you would need to get the tyre off to check properly.As you have insurance why not claim? Share this post Link to post Share on other sites
