David Foster 0 Report post Posted December 20, 2020 (edited) Hello, Seeking some advice please. I have a 2016 520d. auto. Owned it for just over a year. Recently when cruising at around 70-80mph revs are roughly 1600- 1900. When I lightly come off the throttle it feels as though the engine is fluttering. I had my m.o.t. done at a German Car Specialist. With no failures, It needed a new air intake pipe. Had this replaced two weeks later and a diagnostics check carried out. It came back showing DPF, EGR and LAMBDA probe showing as faulty. However it passed the m.o.t. ?? The garage cleared the faults off, however the fault seems to be worse and fault light comes on with a loss of power as well for a short period. According to the garage and my local dealer no recall for my car. However I’ve checked on a couple of sites on the net and the EGR is on recall for my car. Checked it against the chassis number. The car has only covered 37000.mls. Can anyone suggest the best way forward. I have it booked into a Dealer for a “health check” on Tuesday. Thanks in advance. Edited December 20, 2020 by David Foster Share this post Link to post Share on other sites
percha 90 Report post Posted December 20, 2020 Sounds like to me that the car is regenerating the DPF. You need to get the car properly diagnosed with fault codes read and at a garage who knows what they are doing! Sent from my Samsung S10+ using Tapatalk Share this post Link to post Share on other sites
HandyAndy_UK 223 Report post Posted December 21, 2020 Well the EGR recall will probably be the EGR cooler recall... well known and covers a massive range of models. Free of charge job. Check here : https://www.bmw.co.uk/en/footer/quick-links/bmw-vehicle-recalls.html If you have a problem after having work done and a collection of 'related' faults appear, I'd firstly be looking to see if something's been left unplugged. What exactly were the fault codes? Remember that a code doesn't necessarily mean a fault or failure... many refer to information for the advice of the service dept. Share this post Link to post Share on other sites
David Foster 0 Report post Posted December 29, 2020 Thanks for the replies. Garage did not give me the codes. Fluttering is getting worse so the car has gone into my local BMW Dealership for a diagnostic test this morning. Share this post Link to post Share on other sites
David Foster 0 Report post Posted January 7 Well BMW replaced the EGR valve at full price. Despite the car being four years old and only 37000 miles on. Leaves a bitter taste in the mouth. Any idea how long it takes to change a EGR valve....?. Share this post Link to post Share on other sites
percha 90 Report post Posted January 7 Its probably 2hrs labour at a guess. I bet that was an expensive job. EGR must be around £500 for part alone...Sent from my Samsung S10+ using Tapatalk Share this post Link to post Share on other sites
F10er 80 Report post Posted January 7 Egr is about 175-200 depends on dealer and if they put 2 hour labour whole bill in my opinion shouldnt be more than 500 Share this post Link to post Share on other sites
David Foster 0 Report post Posted January 7 Thanks for your replies. Bill came to £425.00. So quite lucky. Cheers guys. Share this post Link to post Share on other sites
percha 90 Report post Posted January 7 Sounds like a good price..Sent from my Samsung S10+ using Tapatalk Share this post Link to post Share on other sites
David Foster 0 Report post Posted January 8 Yes and that was a dealership. Share this post Link to post Share on other sites
q96169we 4 Report post Posted January 13 On 1/7/2021 at 4:05 PM, David Foster said: Thanks for your replies. Bill came to £425.00. So quite lucky. Cheers guys. My F10 520d was built in March 2016 reg in June. It was almost the last one or two months production batch of the F10. Had similar issue at arount 25k miles. EGR valve replaced under warranty. However, it was also subject to the EGR cooler recall. Unless yours has already had the recall done (maybe with previous owner), otherwise, I'm a bit suprised to know that it's built in 2016 but not in the recall list. When I discussed this with the service man at dealer expressing my concern of the short life of EGR valve, he told me BMW noticed the issue and redesign the EGR valve and release some new firmware around this. Thus, the life should be longer now. realoem seems support such claim of redesign of EGR valve. Later when I had the recall, it's the same person served me at the dealer. He told me the recall would have whole high pressure EGR module (cooler, valve, pipe) replaced, check for damage to the manifold (replace if found), and update to firmware. And, he actually remembered my warranty case and told me that I now have two new valve in less than 3 months so I shouldn't worry too much now. Anyway, the car is about 70k miles now. It seems to be ok so far. No one can promise the future though. But, the £425 bill doesn't sound too bad, does it? Share this post Link to post Share on other sites
BFleming 147 Report post Posted January 13 On 07/01/2021 at 16:05, David Foster said: Thanks for your replies. Bill came to £425.00. So quite lucky. Cheers guys. Was that with any goodwill / negotiation? Both EGR and cooler are known issues. I would be putting an e-mail into BMW UK Customer Services, along with a copy of your most recent invoice, appealing to their better side. Share this post Link to post Share on other sites
gIzzE 132 Report post Posted January 13 £425? Ouch. It takes around 15-20 mins to swap the EGR on the B47. I paid £163 for the EGR including vat and bought these..... https://www.amazon.co.uk/gp/product/B07898CGW5/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 It is 3 screws, it lifts out and new one slots in, do screws back up. BMW should be replacing all these free of charge, they are faulty. 10,000s failing. (If you are taking old one out and having to put it back in, because you are looking at it, you might need diag tool to close it up so the valve doesn't bend. If putting in new you are fine.) I know I just put this in the other thread too, but seems to be cropping up more and more so posting it again for reference if people search. Share this post Link to post Share on other sites
F10er 80 Report post Posted January 14 I thought you need diagnosis to close the valve especially if its new? Don't you also need to reset the emission values once replaced? Share this post Link to post Share on other sites
