Bwayeast
E34 Instrument Cluster needed
Hi
My recently required E34 520 touring needs a new instrument cluster.  Display was intermittent when I bought the car (earlier this summer), but is now off permanently.  Any advice as to best place to locate one much appreciated.  I'm based in Chester
Ebay is probably your best bet, unless you can repair your one locally by someone who knows what they're doing?
P.S. Found these guys on Google, but haven't used them myself, so do your own research >>> http://www.clusterrepairsuk.co.uk/repair/model/bmw-e34-5-series-instrument-cluster-repair-service
Edited by Blackman
It's common on these. The 518i, 520i and the diesels all use the same type of cluster. Nothing else will fit. The actual cluster will be fine, it's the circuit board on the back that fails. Any one of the above can be bought, the circuit board unclipped and fitted to yours. The coding chip from the 520i then fitted and it might work.
New boards are about a grand from BMW. Alternatively: https://totaltronics.com/instrument-cluster-repairs/bmw/bmw-e34-lcd-pixel-instrument-cluster-repair-service/
