Stealthy 3 Report post Posted October 17, 2020 (edited) Hi guys/girls Just signed up and hoping to get some trusted advise from you guys if that's ok. Bought a 2002 525i with 70k and first thing I noticed was that when I go for a long drive the temp drops then noticed the heaters don't blow any heat, only cold! Had the car parked up for 3/4 weeks then started and drove approx 1/4 mile (around the block) parked the car up on the drive and noticed burning smell! Opened the bonnet and noticed white smoke coming from the back of the engine also noticed oil residue down the side of the block only at the back also on the firewall. So I'm planning on replacing the rocker cover gasket today, any advice/pointers on the other issues would be greatly appreciated! Thanks Edited October 17, 2020 by Stealthy Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted October 17, 2020 18 minutes ago, Stealthy said: Hi guys/girls Just signed up and hoping to get some trusted advise from you guys if that's ok. Bought a 2002 525i with 70k and first thing I noticed was that when I go for a long drive the temp drops then noticed the heaters don't blow any heat, only cold! Had the car parked up for 3/4 weeks then started and drove approx 1/4 mile (around the block) parked the car up on the drive and noticed burning smell! Opened the bonnet and noticed white smoke coming from the back of the engine also noticed oil residue down the side of the block only at the back also on the firewall. So I'm planning on replacing the rocker cover gasket today, any advice/pointers on the other issues would be greatly appreciated! Thanks Welcome to the forums If you've no paperwork/history to show that the cooling system has been recently maintained; then budget to replace the stat and water pump and top hose, at a minimum and a full coolant flush and refill: Stat (Walher or Behr IMO): https://www.ebay.co.uk/itm/WAHLER-OEM-HEAVY-DUTY-THERMOSTAT-KIT-BMW-5-E39-520I-52I3-525I-528I-530/352992452092?hash=item522ffd5dfc:g:Ub8AAOSwvhxb5spL https://www.ebay.co.uk/itm/Thermostat-BMW-E39-520i-523i-525i-528i-530i-09-1998-on-BEHR-MAHLE-11531437040/273628962360?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=248773511&hash=item3fb58e9e38:g:p58AAOSwWvpbe8w1 Water pump: Meyle: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-528i-Water-Pump-MEYLE-2-year-warranty-11517527799/273898786858?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249249773&hash=item3fc5a3d02a:g:BTIAAOSw7k9dDOvv Top hose: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 Coolant & deionised water (5l of each): Comma G48: https://www.amazon.co.uk/XSG5L-Xstream-Antifreeze-Coolant-Concentrate/dp/B003BPNOXQ/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=comma+g48&dchild=1&keywords=comma+g48&pd_rd_i=B003BPNOXQ&pd_rd_r=0d5d034c-895e-4c0c-9290-295c20e006cd&pd_rd_w=5dd57&pd_rd_wg=UJ4ae&pf_rd_p=01fd0f51-3837-49b3-b7d3-05520a5467f4&pf_rd_r=S3PE3W0BJRRZ1TDH2QF6&psc=1&qid=1602940510&sr=1-1-ac3a866f-801f-44fe-9e94-bb9a271cf6b8 Deionised water: https://www.amazon.co.uk/TUW-TUW5-Ionised-Water-Litre/dp/B000Y8WA38/ref=sr_1_5?crid=2L4FNG30XQNO2&dchild=1&keywords=deionised+water+5l&qid=1602940534&s=automotive&sprefix=deionised+%2Cautomotive%2C155&sr=1-5 As for the gaskets; yes; rocker cover, spark plug and bolt gaskets will need replacing. Probably the oil filter housing gasket too; they all leak (get old and harden/perish with age): Rocker gasket set: https://www.ebay.co.uk/itm/OE-BMW-E46-E38-E60-E53-X5-320i-325i-330i-520i-525i-530i-Rocker-Cover-Gasket-Set/232739494612?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=1529773640&hash=item36305adad4:g:sB4AAOSw9DJa2H2U Bolt seals: https://www.ebay.co.uk/itm/BMW-E36-E46-E39-VALVE-ROCKER-COVER-GASKET-BOLT-SEALS-x-16-A1369/223199039623?fits=Car+Make%3ABMW|Cars+Type%3A525i&hash=item33f7b31087:g:jwAAAOSw6~BbyZza Oil filter housing gasket: https://www.ebay.co.uk/itm/BMW-3-5-7-X3-X5-Z1-Petrol-Engine-Oil-Filter-Housing-Gasket-11421719855/233132077846?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249625062&hash=item3647c13316:g:Y8kAAOSwcOtcZBUo - Re the rocker gaskets; you need to also ensure that the cover isn't cracked or warped; so give that a good once over (and a good clean); shine a bright torch through it from the underneath to see if there are any hairline cracks and also run a straight edge on it to make sure it's not warped. Use sealant on the half moons, corners and seams; not really needed anywhere else; but know plenty of folk that run a very thin bead all the round and never any issues etc. Personally I use Hylomar blue: https://www.amazon.co.uk/Hylomar-HMMS00C-040G-Universal-Blue/dp/B0064M6A6G/ref=sr_1_1?crid=NAGL6TMCMDHJ&dchild=1&keywords=hylomar+blue&qid=1602940895&s=automotive&sprefix=hylomar%2Cautomotive%2C144&sr=1-1 Plenty of How To's re all this on Google & Youtube - Re the heaters; it could be that as the stats failed/failing it's not letting the water circulate fully; could also be the FSU that's failed (could be other things too); gut generally those are the 2 main issues; FSU here: https://www.ebay.co.uk/itm/BMW-E46-E39-E53-E83-X3-X5-HEATER-BLOWER-RESISTOR-MEYLE-C942/190679482553?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Again, plenty of info re this on Google/Youtube 3 1 PL523i, DepthHoar, duncan-uk and 1 other reacted to this Share this post Link to post Share on other sites
Mashmanu 71 Report post Posted October 17, 2020 2nd ^^^ and yes welcome to the forum 70k is a very low mileage so may not have had that much attention engine wise but it’s the age that’s the issue for these engines. Too many plastic and rubber bits that get brittle as Dan says. Being low mileage a full oil and brake service should also be on the list. Another possibility for the heating is the heater valve solenoid on the right suspension turret in the engine bay as you look at it. I would also highly recommend you get INPA and a ODB cable from Cable Shack on the homepage of this forum to see what fault codes are being thrown. You’ll need a Windows 7 or older laptop for best results. 1 1 d_a_n1979 and Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted October 17, 2020 14 minutes ago, d_a_n1979 said: Welcome to the forums If you've no paperwork/history to show that the cooling system has been recently maintained; then budget to replace the stat and water pump and top hose, at a minimum and a full coolant flush and refill: Stat (Walher or Behr IMO): https://www.ebay.co.uk/itm/WAHLER-OEM-HEAVY-DUTY-THERMOSTAT-KIT-BMW-5-E39-520I-52I3-525I-528I-530/352992452092?hash=item522ffd5dfc:g:Ub8AAOSwvhxb5spL https://www.ebay.co.uk/itm/Thermostat-BMW-E39-520i-523i-525i-528i-530i-09-1998-on-BEHR-MAHLE-11531437040/273628962360?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=248773511&hash=item3fb58e9e38:g:p58AAOSwWvpbe8w1 Water pump: Meyle: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-528i-Water-Pump-MEYLE-2-year-warranty-11517527799/273898786858?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249249773&hash=item3fc5a3d02a:g:BTIAAOSw7k9dDOvv Top hose: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 Coolant & deionised water (5l of each): Comma G48: https://www.amazon.co.uk/XSG5L-Xstream-Antifreeze-Coolant-Concentrate/dp/B003BPNOXQ/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=comma+g48&dchild=1&keywords=comma+g48&pd_rd_i=B003BPNOXQ&pd_rd_r=0d5d034c-895e-4c0c-9290-295c20e006cd&pd_rd_w=5dd57&pd_rd_wg=UJ4ae&pf_rd_p=01fd0f51-3837-49b3-b7d3-05520a5467f4&pf_rd_r=S3PE3W0BJRRZ1TDH2QF6&psc=1&qid=1602940510&sr=1-1-ac3a866f-801f-44fe-9e94-bb9a271cf6b8 Deionised water: https://www.amazon.co.uk/TUW-TUW5-Ionised-Water-Litre/dp/B000Y8WA38/ref=sr_1_5?crid=2L4FNG30XQNO2&dchild=1&keywords=deionised+water+5l&qid=1602940534&s=automotive&sprefix=deionised+%2Cautomotive%2C155&sr=1-5 As for the gaskets; yes; rocker cover, spark plug and bolt gaskets will need replacing. Probably the oil filter housing gasket too; they all leak (get old and harden/perish with age): Rocker gasket set: https://www.ebay.co.uk/itm/OE-BMW-E46-E38-E60-E53-X5-320i-325i-330i-520i-525i-530i-Rocker-Cover-Gasket-Set/232739494612?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=1529773640&hash=item36305adad4:g:sB4AAOSw9DJa2H2U Bolt seals: https://www.ebay.co.uk/itm/BMW-E36-E46-E39-VALVE-ROCKER-COVER-GASKET-BOLT-SEALS-x-16-A1369/223199039623?fits=Car+Make%3ABMW|Cars+Type%3A525i&hash=item33f7b31087:g:jwAAAOSw6~BbyZza Oil filter housing gasket: https://www.ebay.co.uk/itm/BMW-3-5-7-X3-X5-Z1-Petrol-Engine-Oil-Filter-Housing-Gasket-11421719855/233132077846?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249625062&hash=item3647c13316:g:Y8kAAOSwcOtcZBUo - Re the rocker gaskets; you need to also ensure that the cover isn't cracked or warped; so give that a good once over (and a good clean); shine a bright torch through it from the underneath to see if there are any hairline cracks and also run a straight edge on it to make sure it's not warped. Use sealant on the half moons, corners and seams; not really needed anywhere else; but know plenty of folk that run a very thin bead all the round and never any issues etc. Personally I use Hylomar blue: https://www.amazon.co.uk/Hylomar-HMMS00C-040G-Universal-Blue/dp/B0064M6A6G/ref=sr_1_1?crid=NAGL6TMCMDHJ&dchild=1&keywords=hylomar+blue&qid=1602940895&s=automotive&sprefix=hylomar%2Cautomotive%2C144&sr=1-1 Plenty of How To's re all this on Google & Youtube - Re the heaters; it could be that as the stats failed/failing it's not letting the water circulate fully; could also be the FSU that's failed (could be other things too); gut generally those are the 2 main issues; FSU here: https://www.ebay.co.uk/itm/BMW-E46-E39-E53-E83-X3-X5-HEATER-BLOWER-RESISTOR-MEYLE-C942/190679482553?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Again, plenty of info re this on Google/Youtube What a response! Legend Thanks dude 1 d_a_n1979 reacted to this Share this post Link to post Share on other sites
waitee 92 Report post Posted October 20, 2020 Dan your always so helpful mate! second all that 1 d_a_n1979 reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted April 7 On 10/17/2020 at 2:23 PM, d_a_n1979 said: Welcome to the forums If you've no paperwork/history to show that the cooling system has been recently maintained; then budget to replace the stat and water pump and top hose, at a minimum and a full coolant flush and refill: Stat (Walher or Behr IMO): https://www.ebay.co.uk/itm/WAHLER-OEM-HEAVY-DUTY-THERMOSTAT-KIT-BMW-5-E39-520I-52I3-525I-528I-530/352992452092?hash=item522ffd5dfc:g:Ub8AAOSwvhxb5spL https://www.ebay.co.uk/itm/Thermostat-BMW-E39-520i-523i-525i-528i-530i-09-1998-on-BEHR-MAHLE-11531437040/273628962360?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=248773511&hash=item3fb58e9e38:g:p58AAOSwWvpbe8w1 Water pump: Meyle: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-528i-Water-Pump-MEYLE-2-year-warranty-11517527799/273898786858?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249249773&hash=item3fc5a3d02a:g:BTIAAOSw7k9dDOvv Top hose: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 Coolant & deionised water (5l of each): Comma G48: https://www.amazon.co.uk/XSG5L-Xstream-Antifreeze-Coolant-Concentrate/dp/B003BPNOXQ/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=comma+g48&dchild=1&keywords=comma+g48&pd_rd_i=B003BPNOXQ&pd_rd_r=0d5d034c-895e-4c0c-9290-295c20e006cd&pd_rd_w=5dd57&pd_rd_wg=UJ4ae&pf_rd_p=01fd0f51-3837-49b3-b7d3-05520a5467f4&pf_rd_r=S3PE3W0BJRRZ1TDH2QF6&psc=1&qid=1602940510&sr=1-1-ac3a866f-801f-44fe-9e94-bb9a271cf6b8 Deionised water: https://www.amazon.co.uk/TUW-TUW5-Ionised-Water-Litre/dp/B000Y8WA38/ref=sr_1_5?crid=2L4FNG30XQNO2&dchild=1&keywords=deionised+water+5l&qid=1602940534&s=automotive&sprefix=deionised+%2Cautomotive%2C155&sr=1-5 As for the gaskets; yes; rocker cover, spark plug and bolt gaskets will need replacing. Probably the oil filter housing gasket too; they all leak (get old and harden/perish with age): Rocker gasket set: https://www.ebay.co.uk/itm/OE-BMW-E46-E38-E60-E53-X5-320i-325i-330i-520i-525i-530i-Rocker-Cover-Gasket-Set/232739494612?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=1529773640&hash=item36305adad4:g:sB4AAOSw9DJa2H2U Bolt seals: https://www.ebay.co.uk/itm/BMW-E36-E46-E39-VALVE-ROCKER-COVER-GASKET-BOLT-SEALS-x-16-A1369/223199039623?fits=Car+Make%3ABMW|Cars+Type%3A525i&hash=item33f7b31087:g:jwAAAOSw6~BbyZza Oil filter housing gasket: https://www.ebay.co.uk/itm/BMW-3-5-7-X3-X5-Z1-Petrol-Engine-Oil-Filter-Housing-Gasket-11421719855/233132077846?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249625062&hash=item3647c13316:g:Y8kAAOSwcOtcZBUo - Re the rocker gaskets; you need to also ensure that the cover isn't cracked or warped; so give that a good once over (and a good clean); shine a bright torch through it from the underneath to see if there are any hairline cracks and also run a straight edge on it to make sure it's not warped. Use sealant on the half moons, corners and seams; not really needed anywhere else; but know plenty of folk that run a very thin bead all the round and never any issues etc. Personally I use Hylomar blue: https://www.amazon.co.uk/Hylomar-HMMS00C-040G-Universal-Blue/dp/B0064M6A6G/ref=sr_1_1?crid=NAGL6TMCMDHJ&dchild=1&keywords=hylomar+blue&qid=1602940895&s=automotive&sprefix=hylomar%2Cautomotive%2C144&sr=1-1 Plenty of How To's re all this on Google & Youtube - Re the heaters; it could be that as the stats failed/failing it's not letting the water circulate fully; could also be the FSU that's failed (could be other things too); gut generally those are the 2 main issues; FSU here: https://www.ebay.co.uk/itm/BMW-E46-E39-E53-E83-X3-X5-HEATER-BLOWER-RESISTOR-MEYLE-C942/190679482553?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649 Again, plenty of info re this on Google/Youtube Hi guys hope your all good does anyone know where or a link to the above STAT and WATERPUMP? As the above sellers are out of stock. Any help appretiated thanks Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted April 7 1 hour ago, Stealthy said: Hi guys hope your all good does anyone know where or a link to the above STAT and WATERPUMP? As the above sellers are out of stock. Any help appretiated thanks Mahle water pump here: https://www.ebay.co.uk/itm/1x-MAHLE-THERMOSTAT-BMW-3-SERIES-E36-320-323-98-99-E46-320-330-X3-E83-2-5-3-0/383861337824?fits=Car+Make%3ABMW|Cars+Type%3A530i&epid=248773511&hash=item595feb2ee0:g:essAAOSwkUJf2knN or Wahler one here: https://www.ebay.co.uk/itm/1x-WAHLER-THERMOSTAT-BMW-5-SERIES-E39-98-03-E60-E61-520-530-X3-E83-2-5-3-0/383606406764?fits=Car+Make%3ABMW&hash=item5950b93e6c:g:NLUAAOSwhele9Q00 Mahle one here with £7 off if you use the discount code: https://www.ebay.co.uk/itm/Coolant-Thermostat-fits-BMW-325-E46-2-5-Mahle-11530139877-11531436823-Quality/333880484455?fits=Car+Make%3ABMW&epid=28015703162&hash=item4dbcd3e267:g:RkYAAOSwkBJgHhL6 Water pump (trusted seller too): https://www.ebay.co.uk/itm/FOR-BMW-E46-328i-328-330Ci-330-PETROL-ENGINE-COOLANT-WATER-PUMP-MEYLE-GERMANY/172725641022?fits=Car+Make%3ABMW|Cars+Type%3A530i&epid=249249773&hash=item2837401f3e:g:njkAAOSwNA1bAXvi 1 Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted April 7 30 minutes ago, d_a_n1979 said: Mahle water pump here: https://www.ebay.co.uk/itm/1x-MAHLE-THERMOSTAT-BMW-3-SERIES-E36-320-323-98-99-E46-320-330-X3-E83-2-5-3-0/383861337824?fits=Car+Make%3ABMW|Cars+Type%3A530i&epid=248773511&hash=item595feb2ee0:g:essAAOSwkUJf2knN or Wahler one here: https://www.ebay.co.uk/itm/1x-WAHLER-THERMOSTAT-BMW-5-SERIES-E39-98-03-E60-E61-520-530-X3-E83-2-5-3-0/383606406764?fits=Car+Make%3ABMW&hash=item5950b93e6c:g:NLUAAOSwhele9Q00 Mahle one here with £7 off if you use the discount code: https://www.ebay.co.uk/itm/Coolant-Thermostat-fits-BMW-325-E46-2-5-Mahle-11530139877-11531436823-Quality/333880484455?fits=Car+Make%3ABMW&epid=28015703162&hash=item4dbcd3e267:g:RkYAAOSwkBJgHhL6 Water pump (trusted seller too): https://www.ebay.co.uk/itm/FOR-BMW-E46-328i-328-330Ci-330-PETROL-ENGINE-COOLANT-WATER-PUMP-MEYLE-GERMANY/172725641022?fits=Car+Make%3ABMW|Cars+Type%3A530i&epid=249249773&hash=item2837401f3e:g:njkAAOSwNA1bAXvi Thanks again Dan your a Legend mate! On 10/17/2020 at 2:23 PM, d_a_n1979 said: Welcome to the forums If you've no paperwork/history to show that the cooling system has been recently maintained; then budget to replace the stat and water pump and top hose, at a minimum and a full coolant flush and refill: Stat (Walher or Behr IMO): https://www.ebay.co.uk/itm/WAHLER-OEM-HEAVY-DUTY-THERMOSTAT-KIT-BMW-5-E39-520I-52I3-525I-528I-530/352992452092?hash=item522ffd5dfc:g:Ub8AAOSwvhxb5spL https://www.ebay.co.uk/itm/Thermostat-BMW-E39-520i-523i-525i-528i-530i-09-1998-on-BEHR-MAHLE-11531437040/273628962360?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=248773511&hash=item3fb58e9e38:g:p58AAOSwWvpbe8w1 Water pump: Meyle: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-528i-Water-Pump-MEYLE-2-year-warranty-11517527799/273898786858?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249249773&hash=item3fc5a3d02a:g:BTIAAOSw7k9dDOvv Top hose: https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 Coolant & deionised water (5l of each): Comma G48: https://www.amazon.co.uk/XSG5L-Xstream-Antifreeze-Coolant-Concentrate/dp/B003BPNOXQ/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=comma+g48&dchild=1&keywords=comma+g48&pd_rd_i=B003BPNOXQ&pd_rd_r=0d5d034c-895e-4c0c-9290-295c20e006cd&pd_rd_w=5dd57&pd_rd_wg=UJ4ae&pf_rd_p=01fd0f51-3837-49b3-b7d3-05520a5467f4&pf_rd_r=S3PE3W0BJRRZ1TDH2QF6&psc=1&qid=1602940510&sr=1-1-ac3a866f-801f-44fe-9e94-bb9a271cf6b8 Deionised water: https://www.amazon.co.uk/TUW-TUW5-Ionised-Water-Litre/dp/B000Y8WA38/ref=sr_1_5?crid=2L4FNG30XQNO2&dchild=1&keywords=deionised+water+5l&qid=1602940534&s=automotive&sprefix=deionised+%2Cautomotive%2C155&sr=1-5 As for the gaskets; yes; rocker cover, spark plug and bolt gaskets will need replacing. Probably the oil filter housing gasket too; they all leak (get old and harden/perish with age): Rocker gasket set: https://www.ebay.co.uk/itm/OE-BMW-E46-E38-E60-E53-X5-320i-325i-330i-520i-525i-530i-Rocker-Cover-Gasket-Set/232739494612?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=1529773640&hash=item36305adad4:g:sB4AAOSw9DJa2H2U Bolt seals: https://www.ebay.co.uk/itm/BMW-E36-E46-E39-VALVE-ROCKER-COVER-GASKET-BOLT-SEALS-x-16-A1369/223199039623?fits=Car+Make%3ABMW|Cars+Type%3A525i&hash=item33f7b31087:g:jwAAAOSw6~BbyZza Oil filter housing gasket: Share this post Link to post Share on other sites
Stealthy 3 Report post Posted April 7 Again thanks for the links Dan the one with the discount could don't fit so gone with the 1st one + any chance you got a link for the top radiator hose and Oil filter housing gasket as they also don't fit the e39 525i. Best regards Saf Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted April 7 (edited) 35 minutes ago, Stealthy said: Again thanks for the links Dan the one with the discount could don't fit so gone with the 1st one + any chance you got a link for the top radiator hose and Oil filter housing gasket as they also don't fit the e39 525i. Best regards Saf Hi pal; they do fit Your engines the M54; so they're the same for the 325i, 330i, 525i and 530i etc Don't always go by what it says on eBay; the part numbers are whats important and they match RealOEM etc Top hose (this is correct): https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 & oil filter housing gasket: https://www.ebay.co.uk/itm/BMW-3-5-7-X3-X5-Z1-Petrol-Engine-Oil-Filter-Housing-Gasket-11421719855/233132077846?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249625062&hash=item3647c13316:g:Y8kAAOSwcOtcZBUo Edited April 7 by d_a_n1979 1 Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted April 7 Thanks Dan appretiated mate 1 d_a_n1979 reacted to this Share this post Link to post Share on other sites
duncan-uk 2,956 Report post Posted April 7 On 20/10/2020 at 20:04, waitee said: Dan your always so helpful mate! second all that Agreed, to me this is what forum bmw5 has always been about. Had so much help over the years and met some great people many only virtually who i consider good friends! 1 1 d_a_n1979 and Stealthy reacted to this Share this post Link to post Share on other sites
duncan-uk 2,956 Report post Posted April 7 Oh and Stealthy we need pics, we like pics, it feeds the beast 2 Stealthy and d_a_n1979 reacted to this Share this post Link to post Share on other sites
Pzero 139 Report post Posted April 8 (edited) On 10/17/2020 at 1:54 PM, Stealthy said: Opened the bonnet and noticed white smoke coming from the back of the engine Ahhh flashbacks to my old 528... Good times. No smells from this though, and the temperature gauge meant that this one wasn't a mystery. Water hose which runs under the manifold had perished at the back of engine end. Enough slack on it that I just cut the tatty last half inch of it off and reattached it. Well, and then had to replace blown rad caused by this. And the 'stat. And some other hoses. And then got a new E39... And did them all again on that as a precaution when I bought it Edited April 8 by Pzero 1 Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted Thursday at 11:22 AM Here's the pics of my e39 On 4/7/2021 at 11:39 PM, duncan-uk said: Oh and Stealthy we need pics, we like pics, it feeds the beast Share this post Link to post Share on other sites
Stealthy 3 Report post Posted Thursday at 11:26 AM 1 d_a_n1979 reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted Thursday at 12:54 PM On 4/7/2021 at 5:19 PM, d_a_n1979 said: Hi pal; they do fit Your engines the M54; so they're the same for the 325i, 330i, 525i and 530i etc Don't always go by what it says on eBay; the part numbers are whats important and they match RealOEM etc Top hose (this is correct): https://www.ebay.co.uk/itm/BMW-E39-520i-523i-525i-530i-E38-728i-Top-Radiator-Hose-09-1998-on-11531705223/372777205999?hash=item56cb40c0ef:g:drsAAOSwI35dhKY9 & oil filter housing gasket: https://www.ebay.co.uk/itm/BMW-3-5-7-X3-X5-Z1-Petrol-Engine-Oil-Filter-Housing-Gasket-11421719855/233132077846?fits=Car+Make%3ABMW|Cars+Type%3A525i&epid=249625062&hash=item3647c13316:g:Y8kAAOSwcOtcZBUo Hey Dan, any links for oil service parts for me please? Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted Thursday at 02:34 PM 1 hour ago, Stealthy said: Hey Dan, any links for oil service parts for me please? What is it you're after pal? Just oil & filter; or are you looking to do the power steering fluid and spark plugs etc? Share this post Link to post Share on other sites
Stealthy 3 Report post Posted Thursday at 06:10 PM 3 hours ago, d_a_n1979 said: What is it you're after pal? Just oil & filter; or are you looking to do the power steering fluid and spark plugs etc? Just the oil and filters for now should be fine will gradually do the rest as i drive her inc brake,power steering and transmission fluids. thanks again Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted Thursday at 06:36 PM I just use TripleQX oil via Eurocarparts (cheaper to buy via ebay than it is their website). Other sellers sell it too. 5W30 or 5W40 is what you need, it meets the necessary specs. Or use which ever oil you want. It's very much personal choice. I do change my oil every 6 months as I do such low mileage. I'd rather have it fresh as can be rather than leave long periods between changes Get the Mann filter too https://www.ebay.co.uk/itm/Mann-Oil-Filter-Element-Metal-Free-For-BMW-3-Series-330-Ci/132504336272?fits=Car+Make%3ABMW|Cars+Type%3A530i|Plat_Gen%3AE39&epid=1825090350&hash=item1ed9dfb790:g:Y7wAAOSwU3tag5Un 1 Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted yesterday at 09:01 AM 14 hours ago, d_a_n1979 said: I just use TripleQX oil via Eurocarparts (cheaper to buy via ebay than it is their website). Other sellers sell it too. 5W30 or 5W40 is what you need, it meets the necessary specs. Or use which ever oil you want. It's very much personal choice. I do change my oil every 6 months as I do such low mileage. I'd rather have it fresh as can be rather than leave long periods between changes Get the Mann filter too https://www.ebay.co.uk/itm/Mann-Oil-Filter-Element-Metal-Free-For-BMW-3-Series-330-Ci/132504336272?fits=Car+Make%3ABMW|Cars+Type%3A530i|Plat_Gen%3AE39&epid=1825090350&hash=item1ed9dfb790:g:Y7wAAOSwU3tag5Un https://www.ebay.co.uk/itm/Castrol-EDGE-Titanium-5W-40-5W40-Fully-Synthetic-Engine-Oil-5-LitRES-MOTOR-/143989624448 This one seems cheap? Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted yesterday at 09:28 AM 22 minutes ago, Stealthy said: https://www.ebay.co.uk/itm/Castrol-EDGE-Titanium-5W-40-5W40-Fully-Synthetic-Engine-Oil-5-LitRES-MOTOR-/143989624448 This one seems cheap? Doesn't mention BMW LL01 or LL04; so not sure if that's right for the BMW engines, someone else may chime in to say if it's right or not But I'm not a believer in 'branded' oils; as long as the oil meets the necessary BMW specs; it's fine More so if you change it out and keep it fresh at least once every 12 months... I used to be (Fuchs, Royal Purple only etc), but not any more I do my oil services on the drive with a Pela pump; draws the oil out through the dipstick tube. Doing that and draining the oil via the sump; there's about 300ml difference in it all, so for me, it's a good way to do a bit of DIY to the car etc x2 oil changes, + x2 filters = less than one tank of VPower for me! So it makes sense to do it once every 6 months 1 Stealthy reacted to this Share this post Link to post Share on other sites
Stealthy 3 Report post Posted yesterday at 09:31 AM 2 minutes ago, d_a_n1979 said: Doesn't mention BMW LL01 or LL04; so not sure if that's right for the BMW engines, someone else may chime in to say if it's right or not But I'm not a believer in 'branded' oils; as long as the oil meets the necessary BMW specs; it's fine More so if you change it out and keep it fresh at least once every 12 months... I used to be (Fuchs, Royal Purple only etc), but not any more I do my oil services on the drive with a Pela pump; draws the oil out through the dipstick tube. Doing that and draining the oil via the sump; there's about 300ml difference in it all, so for me, it's a good way to do a bit of DIY to the car etc x2 oil changes, + x2 filters = less than one tank of VPower for me! So it makes sense to do it once every 6 months Fair enough euros got a 45% mid60 code atm too so works out £40 for 10ltr Share this post Link to post Share on other sites
d_a_n1979 2,902 Report post Posted yesterday at 09:35 AM 3 minutes ago, Stealthy said: Fair enough euros got a 45% mid60 code atm too so works out £40 for 10ltr That's bloody good going! You need c6l for a change anyways. They sell Mann filters too 1 Stealthy reacted to this Share this post Link to post Share on other sites
