PL523i
Defeated by Rear Brake shoes
iv'e never sworn so much at car parts as the rear brake shoes on my new 523i.
Considering the state of the rear brakes, I don think theyve been changed in about 10 years, everything came off relatively easily and no broken knuckles.
But can I get the new brake shoes and spring mechanism on? can i f**k! Gave up after an hour ...you need muscles like THOR and 3 hands.
Unless anyone has some incredible cheats for doing this im going to bow to my common sense and get a mobile mechanic to come round and do it.
Fiddly but not impossible. I assemble it all then i use long nose pliers to get the spring in place.
Perhaps you are using the wrong swear words? have you tried compounding them? ;)
I've run out of swear words! Pretty sure I created some new ones.
Re the pliers, I could do with some new ones I think mine are 40+ years old. Ex forces, Imperial pliers ;)
I've attached a pic of the 'before' situation. There's been no love shown there for a while.
I found them fiddly as well - the worst was when I finally got it together and thought “that looks wrong” so took it apart again... turns out it had been right...
anyway for reassembly I found this image which shows a suggested rebuild sequence which actually, whilst still fiddly, was quite useful.
Yes I found one similar but it was with the bit at the top that the cable goes into that I was struggling with. That came off when I removed the old stuff.
I've got a mobile mechanic coming round Tuesday to do both sides.
However.. Delaying the inevitable. I spied 2 mot failures on the control arm bushes whilst I was there but I don't have the £££ to get it all done at same time.
Starring to wonder if I chose the right project car.
6 hours ago, TerryTibbs said:
One of these makes it an easy job
Yeah I didn't have a pick, I used a small spring puller but still didn't work, it all just fell apart lol. So I used a mobile mechanic and £35 for both sides. Sometimes the easiest solution is to through a bit of money at it and move on.
