Piero
Drivetrain Error & Water in boot
My F10 520d flags the error when going up hill under load . Now ive changed the MAP sensor, cheap and easy to do. it was badly coked up. (but ive  not reset the ecu- is this required?
e EGR was changed by BMW under recall a year ago by the previous owner,  next step would be MAF senor again easy and cheap for me to do.
I still get the problem. My car runs perfectly and does not skip a beat.
However last week my handbrake warning light came on. I checked the EMF located in the boot next to the battery and i found an inch deep of fresh clean water. (i can not find the source or a drain hole)
going up a hill the pool of water flooded the emf & wiring and caused the warning light for parking.
this could have also caused the drivetrain error (as the error only ever flagged while driving uphill )
I have dried the EMF out and parking error / works fine once more..
Any suggestions to how and where the leak is from?
Will this affect the Drivetrain error?
Do i need to Reset OBDto clear that code?
is it worth changing the MAF & EMF?
I seem to remember @535i Andrew posting re weather leaking into his boot. IIRC it was something to do with a piece of trim which had been incorrectly fitted during repairs after he was rear ended. Might not be connected to this issue but could be worth a look.
