jyz
Mixing Tyres?
Hi all, the tyres on my car (run flats) needs replacing soon but I have gotten into a dilemma. My fronts are 245/45 R18 and rears are 270/40 R18. I was planning to change them to Goodyear Asymmetric 5's but they are only currently available in the front only. So is it okay to have A5's on the front and A3's on the back?  Also will having non-run flats on the front and run flats on the rear create any problems?
Current prices for each tyre:
Front - A5 = £110
Front - A3 (run flats) = £145
Rear - A3  = £185
Rear - A3 (run flats) = £178
Can you advice which is the best set up?  Will Front A5 and Rear A3 (run flat) work? or Front A5 and Rear A3? Or will it be better just to have Front & Rear A3 (run flats)?
Front - A5 = £110
Rear - A3  = £185
On which car?
You're better off asking this in the relevant tech section(s) further down the homepage
This is just general chat :)
RF tyres have harder sidewalls and a harder ride due to the stiffer tyre carcass. You're better off replacing all tyres at once to keep the cars handling neutral.
