Johnjonjo
Manual transmission and differential oil change
Hi all
Has anyone done a manual transmission fluid change or differential fluid charge?
My car has done 105k now with no record of either fluid being changed. I have the N47 engine.
Many thanks
i did a differential oil change, there was no drain plug so i had to use this sucking thing, purchased the diff oil from amazon https://www.amazon.co.uk/gp/product/B005UGKJCS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
and purchased a new diff plug with washer for a couple of pounds from the dealer. Its only a litre in there anyway so this is good enough
Word of caution - used diff oil smells absolutely revolting, like raw eggs mixed with putrid sulphur and any clothes you get it on will smell for a while and if there is enough of it then it will stink out your washing machine...
Have a rock solid collection system, lots of cheap kitchen roll and old clothes ;)
15 minutes ago, Johnjonjo said:
Do you have to remove any panels to do the two fluid changes
no Panels for the rear diff.  But to the Auto box i had to remove panels, Not realy heard of anyone doing manual gearbox oil change. The instructions must be on https://www.newtis.info/tisv2/a/en/
search for your specific car and find the how to guide that way
1 hour ago, Johnjonjo said:
Thanks sams255,
How mamy miles had your car done?
How did the old oil look?
 the first time diff oil was changed was at 150k, i didn't see it as ZF did the whole service. at 180k i did the next one it seemed ok.
