marko530d 369 Report post Posted February 12, 2020 (edited) Hi guys and gals Just wondering who on here has the highest mileage on there 5 series f10-f11 diesel or petrol and what big replacement item's have been changed along the way .... Looking at a 525d 3.0d with 153k owned 3 e60s sold 1 with nearly 170k ... Thanks Edited February 12, 2020 by marko530d Share this post Link to post Share on other sites
Lennox 567 Report post Posted February 12, 2020 Mate has 186k on his 545i. Sent from my SM-N9600 using Tapatalk 1 marko530d reacted to this Share this post Link to post Share on other sites
Pedro79 6 Report post Posted February 12, 2020 530d 171k for me. Bought 3 years ago on 136k 1 marko530d reacted to this Share this post Link to post Share on other sites
535i Andrew 3,399 Report post Posted February 13, 2020 8 hours ago, Lennox said: Mate has 186k on his 545i. Given the OP asked about big replacements, I would guess than your mate has had the following done in that mileage a) the gearbox done b) valve stem oil seals c) the upper timing chain to block gaskets d) the vanos O rings e) the cylinder head cover gaskets f) the alternator support bracket oil seal Oil leaks and the 6HP will kill off the N62 equipped E60s which is a pity as they are ULEZ complaint. Share this post Link to post Share on other sites
E39mad 862 Report post Posted February 13, 2020 9 hours ago, Lennox said: Mate has 186k on his 545i. Sent from my SM-N9600 using Tapatalk That'll be an E60 or 61 and the OP wants to know about F10/11's Share this post Link to post Share on other sites
apples12 101 Report post Posted February 13, 2020 (edited) 2013/63 LCI 520d SE here, bought at 33k in Feb 16, currently sat at 153k. Only work done is as follows: 1. Brake pads/discs 2. Tyres 3. Wiper blades 4. 3rd rear guibo donut 5. 3rd set of engine and gearbox mounts 6. Track rod ends (one had split, changed both) 7. Rear diff mount bushing 8. Gearbox service at 90k, next one due soon 9. EGR recall done 10. remapped and EGR delete by Enda Ward 11. 12,604 litres of BP diesel - average MPG (tank to tank) - 47mpg 12. Oil Changes no less frequently than 9-10k miles (serviced by BMW as per the computer and I do an interim oil change myself) it certainly feels like its asking for front and rear shocks soon, a job for after easter! definitely my most favourite high mileage/motorway muncher after 2 golf's! Edited February 13, 2020 by apples12 1 1 marko530d and 535i Andrew reacted to this Share this post Link to post Share on other sites
535i Andrew 3,399 Report post Posted February 13, 2020 16 minutes ago, apples12 said: 2013/63 LCI 520d SE here, bought at 33k in Feb 16, currently sat at 153k. I’ve owned mine for much the same time as you’ve owned yours and it was bought with similar miles on the clock. I noticed today on the 4th anniversary of owning it I’ve done pretty much 20,000 miles in total since owning it. Very different to yours! The repeated engine mounts and propshaft coupling replacements are concerning though. Those and the diff mounts, I wonder if it’s all linked to a deeper issue somewhere? Everything else is fair wear and tare given the massive mileage you do. Good shout regarding the oil changes. 1 marko530d reacted to this Share this post Link to post Share on other sites
apples12 101 Report post Posted February 13, 2020 2 minutes ago, 535i Andrew said: I’ve owned mine for much the same time as you’ve owned yours and it was bought with similar miles on the clock. I noticed today on the 4th anniversary of owning it I’ve done pretty much 20,000 miles in total since owning it. Very different to yours! The repeated engine mounts and propshaft coupling replacements are concerning though. Those and the diff mounts, I wonder if it’s all linked to a deeper issue somewhere? Everything else is fair wear and tare given the massive mileage you do. Good shout regarding the oil changes. The initial change of mounts and guibo was an attempt by shitner under warranty to narrow down the cause of the fine vibration I had between 60-70ish mph, that was all around 55-60ish k, last lot were done in the last couple of months as I had excessive movement on one side of the engine, did the gearbo mount as it was only 20quid (febi) and no charge by the mechanic to fit as it literally was 3 bolts! the rear diff mount splitting is actually quite a common job - more common on the f01 i believe i have genuinely been astounded with how well this car has managed to ferry me up and down the m40 5 days a week and longer trips up to Aberdeen/Glasgow/Edinburgh. previous car's i've kept for 2-3 years tops, at 4 years now with this! Only option I miss is folding seats (didn't know at the time it was an option! didn't even know what LCI was at the time!) only decision I have to make now is do I maintain this and get another 100k out of it or switch up to a G31 (definitely need the bigger boot space at the moment) Do I wait for a hybrid thanks to Birmingham shitty council deciding to implement a CAZ and likely move the goalposts in a few years tim? It will definitely need suspension refreshing at some point this year, gearbox service, aux belts, lord knows how much life is left in the turbo and the dreaded chains. 2 535i Andrew and marko530d reacted to this Share this post Link to post Share on other sites
marko530d 369 Report post Posted February 13, 2020 13 hours ago, Pedro79 said: 530d 171k for me. Bought 3 years ago on 136k Any big items replaced how dose engine/gearbox feel. Is the 525d exact same engine with a detune or different injectors etc Share this post Link to post Share on other sites
BFleming 147 Report post Posted February 13, 2020 My 525d (2.0) has only done 142,000 miles, so not the highest mileage on here in any way. Mechanical failures of the engine & gearbox - None. Zero. Nothing. The EGR cooler was replaced under last year's recall, but it hadn't failed when they replaced it. All it has really needed was 2 rear suspension springs about 2 years ago. They all go, and they're an inexpensive fix. I'm thinking of throwing some preventative money at it if I keep it much longer - which I probably will. It's a superb drive, powerful yet economical, comfortable, spacious (which means also it's a bit big). Fantastic car. By preventative, I specifically mean the (currently quiet) timing chain, HPFP (if that's still an issue on a 2013 car & not a waste of money) and auto transmission fluid change (overdue)! 1 marko530d reacted to this Share this post Link to post Share on other sites
sams255 106 Report post Posted February 13, 2020 my 530D F11 -181,000 miles, Did the starter motor and one rear air bag & compressor. Regular servicing every 10k and regular Gearbox oil & Diff oil changes. 2 BFleming and marko530d reacted to this Share this post Link to post Share on other sites
BFleming 147 Report post Posted February 13, 2020 Just looking on Autotrader now; if you placed little importance on mileage, £6k buys you some seriously nice F10's and F11's with the prerequisite (for some people) 6 cylinders - with a good level of equipment too. Six grand... Share this post Link to post Share on other sites
Pedro79 6 Report post Posted February 13, 2020 9 hours ago, marko530d said: Any big items replaced how dose engine/gearbox feel. Is the 525d exact same engine with a detune or different injectors etc I had to replace snapped active anti roll bar at cost of 2.4k but that was bad luck with a pot hole. Changed all discs and pads last year and had gear box serviced. Sweet and smooth now. Also had remap upto 310bhp last year. Car is as sweet as anything really and my regular stop start commute in traffic and a road sees 37 mpg average. Over 50mpg easily on a long run. Best car I've ever owned by a long stretch and very quick when I'm in the mood. Same engine i think with a detune for 525d but sure someone else will confirm. Share this post Link to post Share on other sites
marko530d 369 Report post Posted February 13, 2020 6 minutes ago, Pedro79 said: I had to replace snapped active anti roll bar at cost of 2.4k but that was bad luck with a pot hole. Changed all discs and pads last year and had gear box serviced. Sweet and smooth now. Also had remap upto 310bhp last year. Car is as sweet as anything really and my regular stop start commute in traffic and a road sees 37 mpg average. Over 50mpg easily on a long run. Best car I've ever owned by a long stretch and very quick when I'm in the mood. Same engine i think with a detune for 525d but sure someone else will confirm. Was that your 1st gearbox service at what mileage thanks I have left a deposit for the 525d Pick it up next week. At £6300 for a f10 seems a bargain to me alot of decent options too Share this post Link to post Share on other sites
F10er 80 Report post Posted February 13, 2020 Having read afew people done their gearbox service done but recently watch a video at an indy's channel on youtibe advices dead against replacing the gearbox fluid. I know ZF advice's to be changed every 40k miles i believe (correct me if i am wrong) i am totally torn on the idea. Share this post Link to post Share on other sites
Skynet5 68 Report post Posted February 13, 2020 1 hour ago, Erhan said: Having read afew people done their gearbox service done but recently watch a video at an indy's channel on youtibe advices dead against replacing the gearbox fluid. I know ZF advice's to be changed every 40k miles i believe (correct me if i am wrong) i am totally torn on the idea. I think it's more like 80k I doubt I'll ever get to that mileage. BMW so no. Others say yes. Do what you want. I'm sure there are plenty of stats backing each option ad valid. Share this post Link to post Share on other sites
Skynet5 68 Report post Posted February 13, 2020 2 hours ago, marko530d said: Was that your 1st gearbox service at what mileage thanks I have left a deposit for the 525d Pick it up next week. At £6300 for a f10 seems a bargain to me alot of decent options too Enjoy. Loving mine, even though its the 20d with just the main package addons. 1 marko530d reacted to this Share this post Link to post Share on other sites
535i Andrew 3,399 Report post Posted February 14, 2020 8 hours ago, Skynet5 said: BMW so no. Others say yes. Do what you want. I'm sure there are plenty of stats backing each option ad valid. ^This. 10 hours ago, Erhan said: I know ZF advice's to be changed every 40k miles i believe (correct me if i am wrong) That's my point I was making on the other thread, ZF will make money from us getting our transmissions serviced. But on the other hand, they made the box so they should know best. So I'm also 10 hours ago, Erhan said: totally torn on the idea. Share this post Link to post Share on other sites
marko530d 369 Report post Posted February 14, 2020 Will see how the box behaves when I collect mine and make a decision. But with 153k am also not to sure. Share this post Link to post Share on other sites
Pedro79 6 Report post Posted February 14, 2020 21 hours ago, marko530d said: Was that your 1st gearbox service at what mileage thanks I have left a deposit for the 525d Pick it up next week. At £6300 for a f10 seems a bargain to me alot of decent options too Yes first one. Done at about 160k. Big difference after. 1 marko530d reacted to this Share this post Link to post Share on other sites
marko530d 369 Report post Posted February 14, 2020 (edited) 16 minutes ago, Pedro79 said: Yes first one. Done at about 160k. Big difference after. Really 160k well might go for it . What was cost if you dont mind me asking Edited February 14, 2020 by marko530d Share this post Link to post Share on other sites
sams255 106 Report post Posted February 14, 2020 I think also if you have never had it changed ever and you got a car on 150k there is a risk there could be some damage if you do change it. Share this post Link to post Share on other sites
Pedro79 6 Report post Posted February 15, 2020 13 hours ago, marko530d said: Really 160k well might go for it . What was cost if you dont mind me asking Not at all. It was about 390 plus vat I think from memory. Had brakes and service done at same time so big bill but smoother since. Share this post Link to post Share on other sites
Linhares 21 Report post Posted February 15, 2020 F10 520d with 194k miles, N47TU. No issues for now. 3 GStarrr, IINexusII and marko530d reacted to this Share this post Link to post Share on other sites
marko530d 369 Report post Posted February 15, 2020 Wow Share this post Link to post Share on other sites
