Robgosty
Problems coding tailgate (F07)
Hi all, as above, pretty sure the button an the A pillar used to open the full rear hatch, using Bimmercode have coded "one press close from remote" and "close hatch from A pillar button" these work fine but botton on a post now only opens small boot, does anyone know how to fix this, very wary of expert mode as dont want to mess anything else up
Rob
Done some digging and found these on net seem to give conflicting info
CAS => REMOTE_KEY_SPECIAL_FCT active
CAS => REAR_SCREEN_IS_PRIMARY not active
CAS => OPEN_RSCR_WITH_REMOTE_KEY_SPFN active
CAS => USE_FBD4 active
CAS => OPEN_RSCR_WITH_PUBU_A_PILLAR active
OPEN_RSCR_WITH_REMOTE_KEY_SPFN should toggle the small and big hatch between Buttons 3 & 4.
And
hatch button floor panel: open and closes the BIG hatch
fob button 3: opens the small hatch (long press)
fob button 4: opens and closes the BIG hatch (long press)
CAS -- 3002 CLM -- REMOTE_KEY_SPECIAL_FCT -- aktiv/Werte=01
CAS -- 3002 CLM -- REAR_SCREEN_IS_PRIMARY -- aktiv/Werte=01
CAS -- 3002 CLM -- OPEN_RSCR_WITH_REMOTE_KEY_SPFN -- nicht_aktiv/Werte=00
CAS -- 3002 CLM -- OPEN_RSCR_WITH_PUBU_A_PILLAR - aktiv/Werte=01 change to "nicht_aktiv/Werte=00"
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_FBD -- aktiv/Werte=01
HKL or HKFM -- 3010_HKLBEDIENUNG -- SCH_TOEHKI -- nicht_aktiv/Werte=00 change to "aktiv/Werte=01"
HKL or HKFM -- 3010_HKLBEDIENUNG -- TASTER_FBD --nicht_aktiv/Werte=00
HKL or HKFM -- 3010_HKLBEDIENUNG -- USE_FBD4 -- aktiv/Werte=01
Neither of these seems to work for me at the moment the things i set with bimmercode are working fine, but just want big hatch to open from button inside car, just opens small boot
I found this on another forum, you may have too...
I think it's odd that half is in German, half is in English; anyhow HKL is Hechklappe - Rear Hatch, Bedienung is Operation, SCH is Schalter -Switch, Taster is a Button, SCH_TOEHKI is the A pillar button.
Another forum (not F07 specific) says:
HKFM 3010 SCH_FBD aktiv Button on key fob will be enabled to CLOSE the trunk
HKFM 3010 SCH_TOEHKI aktiv Button on driver-side will be enabled to CLOSE the trunk
HKFM 3010 TASTER_FBD aktiv Required for SCH_FBD and SCH_TOEHKI to work.
Hi bud, this coding  is the second one in my post (in italics), using Bimmercode I have coded "one press close from remote" and "close hatch from A pillar button" these work fine but button on A pillar now only opens small boot, tried the one you posted but that does not work, think mine it have have got a bit screwed because of the ones I have programmed with Bimmercode, tried reverting from backup but still no joy, the file you have put from the non specific site is how mine is programmed now, in a bit over my head now but the main things are working, two out of three aint bad
Edited by Robgosty
added text
