makeshiftuk
Which PDC Sensor? E39 Sport Touring
Hi all,
Which parking sensor do I need? Seem to be a few options I could find in RealOEM below.
The one in question I'm changing is also pictured below (530i Sport Touring 2002) - old picture, the scrape has since been repaired!!
Edited by makeshiftuk
These for the middles ones IIRC: https://www.ebay.co.uk/itm/BMW-PDC-Parking-Sensor-E39-E46-E60-E61-E65-E66-E83-X3-X5-3-5-Series-66206989069/261795140919?fits=Car+Make%3ABMW|Plat_Gen%3AE39&epid=652993716&_trkparms=ispr%3D1&hash=item3cf434d537:g:OU8AAOSwzpFbIdYY&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qWT7vwlMiqJkdb8XUHPJo%2F9nozN4d60LiP%2BGF6AAoNMnoslX%2F2%2FaX%2BlKfmjOnlFjNTyn8ClCd6hWgapEJg4kRIzzqI0L1t%2B7mGYnZl1UCk6qIWV%2FzNeLGzeABquVC67ZC4xJWGrIcrbqGQPZQyuoJN7QidNx5kJOrb5Zk7IQd0JyaVTaevEH2iO7KhBvq55NleRvPGTiLI2nBLzQnm%2FH5SZsRsFCrIzLaYByJFYNqm0IshhfcnAQLz3%2Fo3e78O0%2BJ2wwBideGJKv5wm3EWpz5jU9hBzjr65oCAFS2tUwQCRUWNWH%2BM8OyQX0lQSxWtFBQD6IuoNtyFMNbQ0ezJkYBvaWRbBvY5lVigQhm9DCx6qHrEXpB1z2M3lFIP46MIcmiaPYCDzCQlbSlXluEaodGseAhatHcWiJR9dK05Fc8F0M6kYAeKBE6ViXOjlH8nacZXQu12UoP6Qt1b%2BSpedPu3FOl0cMCb0pnbuekPIHWkFYoJQT9zvoJPw6g7CjAIAyu4UtIRDbb%2BSSPM%2B6NGGNa%2BKHrjpR%2B%2B9YO2DxZEJeGD%2B3BWDXKMd2eSFfAwqQXH6y3OI%2Fk%2FTBhBnsfHfZWwxo881s%2FQNISdx2huO65FNDgZX9kLSq%2Fxr3nxrQRu65vYpP1LARpO4%2B0EPeCQVNlPhuxt35S3rXnfAUWT5am2kRSmO%2BemOckbxjtbrCn5CGSBIiSZmG9pSiG5Ow2m2EXB19JNv9TiBU1gzbjW4G%2FXOqNODhw%3D%3D&checksum=261795140919810ae196a523448f967b7fd333929d52&enc=AQAEAAACQBPxNw%2BVj6nta7CKEs3N0qWT7vwlMiqJkdb8XUHPJo%2F9nozN4d60LiP%2BGF6AAoNMnoslX%2F2%2FaX%2BlKfmjOnlFjNTyn8ClCd6hWgapEJg4kRIzzqI0L1t%2B7mGYnZl1UCk6qIWV%2FzNeLGzeABquVC67ZC4xJWGrIcrbqGQPZQyuoJN7QidNx5kJOrb5Zk7IQd0JyaVTaevEH2iO7KhBvq55NleRvPGTiLI2nBLzQnm%2FH5SZsRsFCrIzLaYByJFYNqm0IshhfcnAQLz3%2Fo3e78O0%2BJ2wwBideGJKv5wm3EWpz5jU9hBzjr65oCAFS2tUwQCRUWNWH%2BM8OyQX0lQSxWtFBQD6IuoNtyFMNbQ0ezJkYBvaWRbBvY5lVigQhm9DCx6qHrEXpB1z2M3lFIP46MIcmiaPYCDzCQlbSlXluEaodGseAhatHcWiJR9dK05Fc8F0M6kYAeKBE6ViXOjlH8nacZXQu12UoP6Qt1b%2BSpedPu3FOl0cMCb0pnbuekPIHWkFYoJQT9zvoJPw6g7CjAIAyu4UtIRDbb%2BSSPM%2B6NGGNa%2BKHrjpR%2B%2B9YO2DxZEJeGD%2B3BWDXKMd2eSFfAwqQXH6y3OI%2Fk%2FTBhBnsfHfZWwxo881s%2FQNISdx2huO65FNDgZX9kLSq%2Fxr3nxrQRu65vYpP1LARpO4%2B0EPeCQVNlPhuxt35S3rXnfAUWT5am2kRSmO%2BemOckbxjtbrCn5CGSBIiSZmG9pSiG5Ow2m2EXB19JNv9TiBU1gzbjW4G%2FXOqNODhw%3D%3D&checksum=261795140919810ae196a523448f967b7fd333929d52
These for the outer ones IIRC: https://www.ebay.co.uk/itm/BMW-PDC-Parking-Sensor-E39-E46-E60-E61-E65-E66-E83-X3-3-5-7-Series-66206989068/261822774094?_trkparms=aid%3D1110001%26algo%3DSPLICE.SIM%26ao%3D1%26asc%3D40733%26meid%3D4907a6c34eec400b984afb41968e2d29%26pid%3D100008%26rk%3D1%26rkt%3D12%26mehot%3Dpp%26sd%3D261795140919%26itm%3D261822774094%26pmt%3D1%26noa%3D0%26pg%3D2047675&_trksid=p2047675.c100008.m2219
They work perfectly and the outer ones are easy to sort too as the cover just pops off :)
2 hours ago, Clavurion said:
On facelift touring all 8 sensors are the same with angled connector. On sedan all the rear sensors are with straight connector.
My facelift touring had two middle ones straight and both side ones angled. Maybe they have been changed some time in past.
7 minutes ago, AdamB said:
Does anyone have any info on the newer type sensors (part number from @Clavurion:
vs. the older type? (Currently fitted to my car - and starting to misbehave)
Don't think you can interchange them. You need to stick with the same type sensor you already have.
My 2002 model uses the new type, had to change one on my dads '97 E39 a few months back, found out the hard way then that they are not interchangable.
Well I’ll keep them in mind.
they all seem to be responding today, maybe not 100% accurate, but they’re all alive according to the pdc info via my intravee.
