Hi Guys
I need a bit of advice.
I'm after reliable Obd interface or scanner.
I use the car in most cases around the city. From time to time, where possible I "put my foot down" etc. I also use diesel additives.
So far I have noticed dpf regen only once, shortly after I have purchased car.
Just need something to check soot level from time to time and if needed to force regeneration.
What do you guys think about interface on the photo please? Is it good enough please?
Edited by GregGreg
I’ve got android and bought btool pro from the App Store. That allows you to check dpf info, miles since last regen and also force regen. All for 10 quid. I connect through a v-gate I car pro obd connector from eBay.
will probably get a proper cable and software soon but in the meantime the current setup is good for checking coolant temps, dpf and error codes.
Just bought the Carista dongle purley to use with BTOOL Expert, it comes with a free month sub to Carista but ;m yet to use it. £11 from Amazon.
Hi Guys
Thank you for a swift reply. I will give a go with BT interface and btool. GoNzO, did you had a chance to use Calista to regen your dpf please?
13 minutes ago, GoNz0 said:
No m8 I have no need to install Carista's app.
Right. I'll get in now, sorry.
I have purchased adapter and downloaded software. I will give it a go.
I'm thinking about removing dpf for good at the beginning of the next year. Just doing a bit if research at the moment.
