simufly
Help required
P plate 525 touring.
Just got the car back from an inspection 2 with a note that the brake switch had been changed. No explanation.
a couple of weeks later every time I brake and release I get an "EGR regalt" caption on the contol warn panel. This has now gone to "brake circuit fault." The brake lights are working
Any boffins with an idea what is going on?
thanks
Simon
I suspect it doesn't actually say EGR is 'regalt' (Blocked or barred). Maybe double check that? If it is an auto, the brake switch not only puts the brake lights on but it also tells the EGS you have the brakes on.
