Wolfgang009
Bmw e60 dsc issue
Hi all,
I am having problem with my e60 2007 525i. I have had the dsc light on sice bought and wanted to fix it. I have scanned through Inpa and get several code from szl and dsc please see attached picture. I have changed the SZl unit and coded the new vin using ncsexpert but still same issue. My question is how do you remove or deactivate the brake air flaps from the car system as they are not mounted on the car? And other question is on Ncsexpert I do not have the option to code my dsc when reading ecu the dsc just does not appear but I can read fault through inpa by going directly to chassis-dsc then read the faults. If someone could help would be greatfull I think it is a coding problem but not very familliar with ncs. Thanks
DSC = EHB3
And I wasn't aware you could decode the vin with NCS, you have to do that with WinKFP.
Yes via winKFP my bad. So I just code the ehb3 then? I will try it just now and see how it goes then let you know. Im not used to this at all everything I do I verify online first in case the car does not switch on
@GoNz0 so I went through ncs expert selected ehb3 and execute jod under sg_codieren then same for szl fired up inpa cleared faults and still the same. Im I doing it correctly or missing some stuff? It seems too easy and straight forward so I thing I am missing something. Inpa does not give me the option to select the szl please see attached pic. If you could assist me please as I am really struggling with this
So I tried to use winkfp but I cannot see the spdaten files that needs to be loaded. But when I use tools32 I can see that the szl the vin correspond to my car vin. This is what I did on tools32 like 2-3weeks ago so the vin is good for the szl. Now what do tou think I should do?
Update guys fault cleared perfectly wouhou thank you for helping out. So for those having the same issue if it worked for me might work for you
1. Changed Szl Vin Number using tool32
2. Verified Dsc Vin using tool32 to make sure everything was done
3. Then using tool32 look for dsc_60pp
then test_auto_codierung as I was not able to locate Lenkwinkel ausgleichen so trial and error and it worked.
