fizz
Issues connecting the car to the computer via cable
Hi guys,
Got my cable through and want to hook up my E60 with the computer. So i have read numerous articles and watched a couple of vids to sort the configuration out.
I have set the latency to 1 and Com port to 4 along with checking the obd.ini file in C:EDIABAS\Bin folder to make sure that the Port is set to Com4 there as well. (it wasnt but i changed it accordingly)
As you can see from the screen shots, the black dots are showing flickering on the left side of the window and when i try and load something up like the standard functional jobs option i get an error as per screen shot.
Any advice on what im missing? I have the K+DCAN cable and i understand that it should be set to DCAN but i have tried both for good measure but still no luck.
Cheers in advanced
Fizz
On 8/19/2019 at 4:25 PM, know-dice said:
Have you checked EDIABAS.ini should have line - Interface = STD:OBD
I find the EasyConnect Utility quite handy for changing these files.
Just checked and that's already set to OBD.
Looking at your pictures in the first post one shows the com port set the 4 and one of the text file shows it set to port 1 these need to both show the same port number
Chris
