CountryGents
What oil for diff and manual gearbox
Ive been looking online and cant actually be sure which oils I need for a 2.5d diff and gearbox. Ive got a rumble in the rear which gets worse on a left hand bend and I really cant identify if its one side or the other or the centre. Id like it to be a wheel bearing really but........
So ill check the diff oil first (no leaks)
Im a bit old fashioned and have a drum of ep80 but I bet that's not suitable for either lol
Lee
If it gets worse on the left hand band, as you noted it should the right wheel bearing.
On a separate note, if you want to quiet down the diff/gearbox, add Liqui Moly Ceratec (8% of the filling capacity). It worked wonders in my case - very clattery gearbox at idle in my high mileage 525i.
As to the oil BMW says this 83 22 2 365 987
If you pop that into autodoc you get GL5 75W90 oils.
https://m.autodoc.co.uk/car-parts/oem/83222365987
For the gearbox BMW stipulates MTF-LT2, namely 83 22 2 339 219
This translates into GL5 75W80 gear oil
https://m.autodoc.co.uk/car-parts/oem/83222339219
