Jemster
Dull and Duller
Here's a couple of incredibly dull questions proving just how few problems I can find with this car! :D So far my post count is embarrassingly low as everything has been great...
The biggest gripe I've found is with the front suspension. Is it just me and my car, or are these cars genuinely a little bit clunky going over rough roads? The dealer changed the wishbones for me, it made a slight difference (and certainly helped with the overall feel) but even after going back to the dealership last week and going out with the technician and picking a nasty section of road, he just reckoned that it was standard suspension movement. He took it away onto the ramps and can find no fault. To my ears, it just doesn't seem well damped and I can hear a light clunk when, say, going over a speed hump, as the suspension decompresses on the trailing edge. Also on torn-up road surfaces it seems very noisy at the front. There's no clunk sensation to be felt on the steering wheel so I'm doubting it's rack related. If I were to compare with my old E46 M3, I'd say it was top mounts, but... no fault found... so would I be throwing money away chasing this? Maybe it's the run-flat tyres?
Second dull question... The tailgate release on the remote key fob releases the window hatch (long press) but only works with the car already unlocked. Is there any option for this to work with the car locked if I only want the tailgate to unlock/open? The manual says something vague about some specifications / equipment making it only operate in this manner but no clarity on why/what equipment etc... Every car I've ever owned with a boot release button has worked with the car locked. Perhaps there's a coding option to make this work when locked?
That really was dull... :D
Haven’t got a tourer , but my f10 started out with run flats but have regular tyres on and my suspension seems a little hard , so maybe tyres ???
Sorry, do you mean your suspension seems a little hard with regular tyres on? Or the runflats?
Mine has runflat Michelins on it, with a good 6+mm of tread so going to be a while before I swap them over for anything else. It's an M-Sport so I guess the suspension is slightly harder than an SE, but I'd certainly not call it hard or sporty :)
It's so hard to define what this is, it's not a hard metallic clunk or rattle, it just sounds like something isn't properly damped. I'm not getting the usual dull thuds of metal on rubber that I get from the back end, or from my previous Audi A4 (it also had mid-40k mileage, but of course no runflats). I'll try and make a recording, but suspect it'll be too quiet to be distinguishable.
Maybe they're all like it. If I drive <5mph I guess that'll shut it up. Or maybe it's time for a stereo upgrade :)
Your symptoms sound similar to those I had on my F11 when going over a bumpy road surface it sounded like the shocks were bottoming out and clunking. I had it in for the dealer to try repair it. I went for a test drive with one of their senior technicians who heard the noise. I left the car with him and the lower front wishbones were replaced and then the offside shock absorber was replaced. The drove the car with their electronic stethoscope attached and still the noise remained. It never did get fixed but it stopped worrying me as the most critical parts were replaced with the same effect so it wasn’t as if the suspension was going to drop off.
I had run flats but the noise was nothing to do with those. I think it was an inherent noise within the design of the shock absorber or top mounts.
Edited by Matthew Ashton
Interesting. Yeah, I'm thinking it's "just the car". I am a little surprised as overall it is so refined and well behaved. Nothing to get worked up about, I am terrible with noises that nobody else ever hears, but if there is something wrong I'd rather it was fixed under the AUC warranty than out of my own pocket :)
Now to try to stop that little compartment door below the light switches from buzzing/rattling gently.... :D
Sometimes I think my car (and the E60s before) is a bit crashy from the suspension. There is nowt wrong with my suspension components or tyres.
But when you can push such a big pudding of a car into a bend at 60mph, it grips and goes round the bend like it's on rails, I give a smile each time as I know it's planted and any suspension crash is usually down to poor road surfaces.
On new or decent sections of road it's sublime.
