JonAre 0 Report post Posted July 5 Hello Intravee users, Am new (late?) to the Intravee II for the E39 and seeking some help - please. Purchased a unit from a fellow bmw5 board member here and am seeking to add functionality, not audio, to my 540i. Plugged only the iBus connector into the Intravee and it seemed to work for a few minutes - folding mirrors on remote lock/unlock for example - then the extra functionality stopped... Decided to update the EPROM without any luck. Using the "downloader-v7.50-44" application. -the serial port "opens" - COM3 with a (pretty fast) baud of 115200. -loading (Open Firmware) the most current build v6.02-7155.blf appears to be accepted. -flashing (Program Firmware) the Intravee returns "Initializing ... Not in application or bootloader? Check cable?" (attached image) Is there another program missing? Need a different or special USB-Serial cable? From another thread, understand there is a fuse. Can one pry the case apart to check? Any help would be appreciated - thanks!! Share this post Link to post Share on other sites
d_a_n1979 2,222 Report post Posted July 5 4 minutes ago, JonAre said: Hello Intravee users, Am new (late?) to the Intravee II for the E39 and seeking some help - please. Purchased a unit from a fellow bmw5 board member here and am seeking to add functionality, not audio, to my 540i. Plugged only the iBus connector into the Intravee and it seemed to work for a few minutes - folding mirrors on remote lock/unlock for example - then the extra functionality stopped... Decided to update the EPROM without any luck. Using the "downloader-v7.50-44" application. -the serial port "opens" - COM3 with a (pretty fast) baud of 115200. -loading (Open Firmware) the most current build v6.02-7155.blf appears to be accepted. -flashing (Program Firmware) the Intravee returns "Initializing ... Not in application or bootloader? Check cable?" (attached image) Is there another program missing? Need a different or special USB-Serial cable? From another thread, understand there is a fuse. Can one pry the case apart to check? Any help would be appreciated - thanks!! Moved to the relevant Intravee section; someone will be along soon enough to help I’m sure Share this post Link to post Share on other sites
JonAre 0 Report post Posted July 5 Thank you! Is it a specific forum? Share this post Link to post Share on other sites
MParallel 6 Report post Posted July 6 Yes the Intravee subsection. Not sure if the other connector is needed, but just to rule it out did you try and connect both? Share this post Link to post Share on other sites
