erv77
Stall / Fuel starvation - end of my tether!!
Hi all, e39 530i touring auto - 2001 with 155k. 3k miles ago, engine work included all new coil packs, plugs, rocker cover, vanos seals changed, ICV and MAF cleaned, both cam sensors, check rubber for vac leaks - all good. DISA and CCV replaced a little while back. It ran absolutely amazing after all this work (also changed the entire cooling system).
last few months it started to occasionally take a few tries to start, starter would crank for a bit, then sometimes i'd get a smell of petrol, it was bit hesitant, rough idle, hunted the gears. 3 weeks ago it conked out (in the middle of Normandy!!), fuel pump making some whirring sounds. Fuel pump and fuel filter now changed.
today, back to stalling - intermittently takes a while to crank, starter spinning. In traffic, I release the brake, it pulls and as soon as I touch the throttle pedal, revs dip and it either lunges forward or conks out. I'm going out of mind WFT is it now!!!!!
any help much appreciated,
thanks
20 minutes ago, erv77 said:
both CPS were changed - febi bilstien, just worried in case one of them has failed
Get codes read first
Secondly; for sensors like those, only use OEM BMW; aftermarket ones tend to either fairly quickly or not work at all, unfortunately
Yeah but febi stuff is supposed to be good! I get the 0171 0174 code and the CPS code occasionally. Hoping there's a clue in the cranking issue followed by petrol smell. I have read up on many posts and have changed all the usually culprits
I'm with Dan on the sensor issue; always get OEM.
For coolant hoses and simple stuff yes, for sensors, OEM all the way...
Ok cheers, so I have the original cps, and want convinced they were knackered, so let's say I swap them out and still have the same problem, what next??
When it conks out, are you 100% sure the fuel pump is priming when you're cranking it?
I had an intermittent fuel pump relay a while back.
The car died for no reason and then wouldn't start.
I replaced a cam sensor as it had a code present, but turned out it was the relay.
Aren't they o2 sensor related, running lean issues.  If you have the original crank sensor then try it to eliminate it as an issue. The symptoms do sound exactly like crank sensor issues, (been there, done that a few times myself).
FWIW I personally disagree with changing out these type sensors as a maintenance item if there was nothing wrong with the original.
Keliuss
Cheers guys, I had changed the CPS as I originally thought the were knackered, had the codes come up. Good shout re the relay, will check that out (once I figure out where it is!)
Not had chance to swap out the CPS yet, but further observation is that this only happens when the car is facing downhill! Unplugged MAF this morning and did a 70mile trip, didn't conk out, although you can feel the subtle difference of it being unplugged! I have INPA on one of my laptops, is this likely to help pin points issue, want avoid throwing new parts at it (anymore!)
Yes me too, I tried some supposedly good new sensors from the same supplier Vauxhall use as OE (only realised that after fixing my nieces car!) but they just didn’t work in the 530i. Got genuine BMW ones & it was perfect.
Unfortunately it seems just removing what was a perfectly good sensor can break it, I read that on here somewhere.  Personally speaking I have a big pile of genuine used cam sensors I pulled of spare engines & from cars at the scrappy, non of which worked!
Fuel pump relay would  intermittently fail on my old E34 535i, difference car admittedly, but that just cut for a second or so, usually when trying to put out of busy junctions! That took a couple of very frustrating years to find...
