Ace5
E39 Sill rust
I know this might be a 'how longs a piece of string question', but any idea on the best way to approach repairing the rust pictured? Hopefully not too expensive. any recommendation for Essex, or London near Romford where someone can have a look?
Front nearside, I couldn't remove the jacking point pin as it's been butchered, so might need drilling out?
Thanks in advance.
IMO get this to a few bodyshops and ask them to quote you; it looks superficial in some places, but it could be a lot worse when the covers are removed.
Prices can vary, wildly at times, so best not to guestimate and speak to the pro's instead and see what they say, hopefully it can be sorted without having to replace too much metal :)
Could be £300, could be £800 - depends how much needs cutting out and how far in it goes (if it goes up the return to the floor pan other stuff like fuel tanks and brake lines have to come off)
Cheers,
Rob
Hi All,
Thank you for the replies. We had a passing in the family so this slipped my mind as not important for a while, but need to get back to it. I do appreciate you taking the time to reply.
I've removed the covers and it appears to be predominantly  around the front jacking points. I've taken it to one rust repair place/person and they were all keen and seemed to think minimal work and then disappeared and ignored calls. So didn't chase them more than twice to pay them for work.
It appears to be just around the front jacking points. I think this might be down to the car having a sunroof fitted.
With wheel arch liners outs, fuel tank area seems good, wheel arches etc seem good.
The one chap I did speak to seemed to suggest cutting the whole jacking point before proceeding, or ignore, so not sure sound advice and perhaps didn't want the work.
Photos start from read offside to front offside, then read nearside to front nearside. sorry for screenshot, was easiest way to shrink photos and send to work email to post online
If anyone has any recommendations for someone to take a look in Essex that would be great.
Thanks again.
I confess I can't see much from those pictures, but my advice (based on my own recent experience) is to double in your head the amount of expected work. Mine turned out to be much, much worse than expected once the flappy wheel came out and I had three out of four jacking points completely rebuilt. From what I can work out, the supports in the jacking points come loose causing the sills to fold and crack the underseal, which then lets moisture in and they rust from the inside out. Mine were actually held together by underseal in places.
