Andyrt200
E39 parts
Hello,
Can you give me a price so I can order some of these for a 2001 touring.
51248190688
Gas pressurized spring (is that the pair? They should be the ones for the glass)
Inter. lateral trunk lid trim panel for left & right in black
51498216725
51498216726
Stop buffer
51248226064
Insert
07417203297 (do these come in a pack?)
Left trunk lid trim panel clip SCHWARZ3
51498217213
Right trunk lid trim panel clip SCHWARZ3
51498217214 (I assume this & the one above come in the pack of 3?)
Everything above should be for the rear boot lid.
But I also want some of these slide on captive nuts (I think they have a rubber coating to protect the paint) to go on the front wings to hold the arch splash gaurds, where there is a screw missing here:
sorry I can’t find a part number for those!
On 05/04/2019 at 09:12, cotswoldbmwmini said:
If I can get your REG or chassis I can look into the above for you.
Kind Regards
Sorry missed your reply, the notifications aren’t working for me.
The Reg is F13 MDT
What is the part number for these if you don't mind me asking, please?
Cheers,
Rob
Cheers,
Rob
I’m actually still not sure, even after a chat on the phone & sending more pictures I just realised I ended up with the wrong ones!
Previously I just ordered new screws. I ended up with the wrong larger ones ending in 964 when I got them from my local dealer. I did get the correct screws in my last order here (ending 161). But I have ended up with the body nut for the larger ones again this time!
In hindsight I should have given the part number for the correct screw.
I think the larger screws are for actually holding the wing to the car body, I don’t remember having taken any off that big when removing the trim. But I’m sure they do appear on the page you’d expect the trim screws to be on, hence easily mixed up.
On a different note be careful with the touring boot plastic trim & clips they do cost a fair bit, I will be gluing the main trim panels back on, the pair were almost half the original quote!
31 minutes ago, ttrw2 said:
Aha thanks, found them
Screw 07147129161
Body nut 07129904217
Ah great thanks, yes its the  position of numbers 8 & 9 that throw you in that diagram!
If you remember can you confirm if your new nuts have a rubber coating on them when you get them?
3 hours ago, ttrw2 said:
Not rubberized from memory, plus a quick google suggests just coated black to match arch liners:
Will let you know
I have some of those screws, (in my pictures above) they are indeed just plated in a nice black finish. It was the nuts I was wondering about, a quick search like you did for the screws would suggest they’re not rubber coated, I could have sworn the ones I took off did have a rubber coating. It’s not nice pushing the standard metal slip on nuts over your lovely fresh new paint!
13 hours ago, oxo said:
Hi have you still got trunk clips ending 213 cheers STEVE
You'll need to start your own thread Steve, this will be lost on this thread
Plus BMW Cotswolds aren't open for business as of yet as far as I'm aware
I found when doing the rust on my friends SE it had plastic clips here instead. Will try to remember to look into this when things get going again, they are much neater.
Thank you for your enquiry and apologies for the delay due to Covid-19
We now have a skeleton staff on site to deal with enquiries and hopefully start sending out orders in the next week or so
If you still require a quote then please resend your enquiry to partscheltenham@cotswoldgroup.com and we will respond asap
Many thanks
