Joss
Ignition switch removal.
Can anyone help with the removal of the ignition switch. Mine seems to be either loose or faulty. I remover the lower cowel and several bolts that appear to be holdi v the upper cowel in place but it won’t come free. I can see what looks like loaction pins with washers that seem to make it impossible to remove. From what I can see the ignition switch is held by a grub screw which I believe is loose but I need to access the barrel to check it.
 Has anybody got a barrel out?
Very different affair on E12 car's
If the E12 column is similar to an early E28 then this topic may help.
