Steve540
e32 750iL Calypso Red
Thanks Steve. it is quite impressive from what I remember, haven't driven her for 6 weeks due a broken ankle and won't be for a while yet either! San Marino Blue with alot of extras and features. Would love to see the G11 parked up against the E32 or even E38!
Ahh that’s far from convenient @sanjx!
That sounds lovely. I’m sure it would make my old 7s look extremely dated haha
I’d like a f01 as a daily when our office opens up. 7 series are just superior
I had an F01 before the G11 and they've certainly continued to evolve generation to generation yet retain their familiar driving style and switch layout
What was the F01 like @sanjx
I would love a 760li F01. There’s a lovely white on black one for sale atm. But in reality I’ll probably get a 740d
This arrived all the way from Germany
Edited by Steve540
The F01 was very good, really enjoyed it. Comfy and balance of speed and economy. The 740D my freind had and it was similiar to the 730D but slightly quicker. I would go 730d over 740d to be fair
16 hours ago, Steve540 said:
It’s for the e38 @sharkfan
I like the sport lip that’s on the e32
If you are after the full Alpina look you might want to get hold of these cut-out trims for the rear bumper - Alpina will only sell them to an owner with the proof of both full chassis numbers but these guys are making copies.
http://alternative-parts.eu/en/sklep/rarytasy/alpina-diffuser-for-the-bmw-e38-exhaust-system/
It's a bog standard E38 rear bumper with a cut outs for the Alpina dual pipes on each side;  and then a small trim to go around the pipes to make it look tidier.
Nah! 740d with twin turbos for me :D
So, I failed the MOT on two rear arms, ABS fault and a missing seatbelt (oops)..
Obviously the rear seat belt was easily sorted. Was hid underneath the rear seat.
Next I fitted 2 rear arms which was easy enough. I plan on doing a suspension overhaul during the winter when the car is off the road, but since I kinda need it atm to get to places I'm just doing whats needed for the MOT
I also replaced a couple of SLS Flexi hoses for the rear suspension while the car was in the air. Got the hoses from BM
Then I replaced the front coolant temperature sensor.. the rubber O ring on the old one was out of shape and caused a massive coolant leak while the car was off the road
c9730a81-a875-4a67-a6fb-8317e1196b94-jpe70fba3eb-3de1-416c-bf0e-fe2d177b653d-jpe
Started into trying to diagnose the ABS fault. I read the codes with INPA and 'brake pressure sensor' fault appeared. So.. I decided to test the sensor before shelling out £120 for a new one. I broke out the multimeter and everything checked out. I then tested all of the wheels speed sensors on INPA and they checked out to0. That meant the only thing left to test was the ABS module . So off it went to England to get tested/repaired and thankfully it was at fault and they were able to fix it. Some are unrepairable and the unit is 3k from bm!. At least now theres no dash lights on ! which is a rarity for an old bm haha
8765daa5-dbbd-45ad-865b-405e9615848f-jpe
Passed the retest with no issues. MOT tester was more interested in talking about her than actually testing it lol. Didn't know she passed until I seen the certificate laying in the passenger seat.
While I was waiting on the ABS module to get repaired I thought I'd do a bit of interior work. The head unit didn't work, there was a backlit screen but that was it.. no radio, nothing. It also didn't fit properly, it looked absolutely awful. So I pulled it out and quickly realised it was of an e53 x5 lol. So I bought an e38 one from a friend in England in perfect condition alone with a proper e38 surround. Plugged it in and ... it didn't work either. Had the same problem with the 740 I had which was the outdated traffic master feature in them. For some reason it blacks the screen out, but you just have to bypass it in the boot.
With the screen now working, there was still no sound of the radio. Again, had this problem with the 740. So I pulled out the radio module deep inside the boot.. replaced the fuse and took the module apart to address the 'dry solder' problem a lot of e38s suffer from. So I re soldered all of the common dry solder joints, reassembled but still no sound. Decided to borrow the amplifier from the 540 and that fixed the problem. So, got an amplifier from my mate in England and reassembled everything.
2a3bb1d1-6662-42ca-a370-e2bdbe7ffe2f-jpee414024e-e0f5-4346-a0f2-bb6af1f15b35-jpe
Since I got the car the gearbox would always go into sport mode. I actually knew about it when I bought it, bit of a risk but I thought it was something electrical and not an actually gearbox fault. Friend in England sent over a gear shift selector which took 2mins to replace and cured the problem. Also replaced the broken leather boot around the gearstick selector. So easy enough fix, operating perfectly now
5a814e4b-3dc4-4ca8-9b60-318968ce7721-jpe4822285a-905d-40cd-a09a-232e114a780a-jpe
Clayed it over easter which took forever but it was worth the effort.
48c643b0-b01b-4f28-b422-83b9f50725d5-jpeb19463e5-cc41-4d64-8743-e4b3479c0de8-jpe
Edited by Steve540
The e38 has a very slow coolant leak coming from the back of the engine. So I've decided to stop using it as a daily driver so I can address any outstanding issues.
So I bought this of my friend to use in the meantime
Its a 2000 750i swb, 1 of 113 with a cool buffalo interior, 1 of 5 with that interior. It's absolutely immaculate, the work he has done to it is incredible.
It's orient blue with only 67k on it
Sat on bilsteins here but he has since fitted a new stock SACHS suspension. I prefer the bilsteins, maybe something I'll change in the future.
Edited by Steve540
Currently working on the black 750iL. I'll update when finished
Meanwhile, I got another alpina lip. So it looks like the inevitable is going to happen to the blue 750, yea the daily that I was going to keep standard :blink:
Replaced the corner trim on the swb 750 as the old one was damaged. The replacement trim wasn't perfect so I repainted it, which led to repainting all of the front trim pieces to make them match.
Screenshot_20210918-222132_Gallery.thumb.jpg.a9f4dbb1d0ce72d8d28e54f2a8b7e58b.jpgScreenshot_20210918-222028_Gallery.thumb.jpg.0589943e98cd851071e007896c10556b.jpg
Also sent the car in for some bodywork. It's looking very sharp now. Couple areas of surface rust were addressed. Thankfully it was very early stages.
Screenshot_20210918-222155_Gallery.jpg.8abf8cfef1cfcc50808022bf860e4c99.jpgScreenshot_20210918-220916_Gallery.jpg.0c71eac78181fd557611ac9034aa6047.jpg
Started to work on the black long wheel base. It had a coolant leak at the back of the engine which led to me buying the short wheel base one and use it as the new daily driver.
Some pics before I started working on it
So I started into it..
Took the injectors out and couple broke #standard. The plastic is notoriously brittle
Intake manifolds off
received_604747020679538.thumb.jpeg.50afce8d54209c9fbd03c4a231a6abdd.jpegreceived_233314798719847.thumb.jpeg.8c185cfcc4f244492bc058c11913cbe1.jpeg
I then doused the place in paraffin and got the steam cleaner out. The rhs was a mess due to a leaking power steering pipe which is standard fare on these.
There are two coolant pipes that run from the water pump and connect into a coolant accumulator at the back of the engine. The leak was coming from the accumulator end, around the large pipe.. so I suspected it was the big O ring inside there that had started to lose it's seal. I got new seals and gaskets for the accumulator so decided to remove it and replace the lot
The accumulator is held on with 6 bolts. 4 out of the 6 snapped on me. Just to give an idea of how tight for space this is I had to use the front camera on my phone to see what I was doing.
It was a real effort to get it off. It was seized on with the rusty studs but I managed to get it off. You can see the big O ring which was causing the coolant leak. Most would have removed the water pump and taken the pipe out that way but I wanted to cover all bases and replace the gaskets as well.
I managed to get two nuts on each stud and slowly got the out with a spanner. If this hadn't of worked it would have been an engine out job because there was no room for anything larger than a spanner back there. Was a relief to see them out. Worthy of a photo..
While I was fitting the nuts to the studs, I pulled my hand up over the engine bay, hit my elbow on something and dropped a nut into the valves  it fell straight down into one of the oil drains. I tried fishing it out with a magnetic but couldn't find it. So I removed the sump and found it laying in it. Ive got the valve covers back on now to make sure I don't drop anything else in, feel like I've used 2 lives in this job already..
Just have to get everything cleaned up and refitted now..
Edited by Steve540
The rear lights on e38s yellow at the reverse light bulb. So I sanded it back and buffed it up. Came out nicely. Also washed it for some better pics
received_585076439243068.thumb.jpeg.d3cd776bab19970686f6cbbbd77c059d.jpegreceived_577350393513265.thumb.jpeg.c5b587f1fe7adb1496bd7afd86e439bd.jpeg20211010_073933.thumb.jpg.e808538a760f0fe46ea2e784d15a11b4.jpgreceived_414240380092174.thumb.jpeg.7882125c45f6e50d71d7db62e8e4a95a.jpeg
