Rydal
Text message on display
On 2/22/2019 at 7:19 AM, SuperDave said:
Aside from Carplay itself, did you want second phone support?   Should just be a few more simple coding changes.
Hi, No I don’t require the multiple phone functionality, it was just the Apple Carplay I was after. It appears that Carplay can’t be remotely activated for the 2019 iDrive, so I will need to find someone in Scotland who can do this. The company I was talking to is a 1000 mile round trip.
On 01/03/2019 at 07:58, GaSelle said:
What is the additional steps to allow two phones to connect at the same time?
You needed extended bluetooth features coded in.
@Richywiseman, yep I'd read that too about remote activation. What a pita.
On ‎1‎/‎15‎/‎2019 at 10:08 PM, sjak92 said:
correct
Im having another go at this,gave up last time as I seemed to be getting nowhere,
I don't seem to have the HU-NBT menu,also the menus I do have in expert mode seem to be in German mostly,tried asking bimmercode for advice but the were not much help,
Any ideas,or can you direct me to the correct menu,id appreciate any advice you could offer
Can you search modules using bimmercode? - pretty sure ts BLUETOOTH_2ND_HFP you need active.
Otherwise I'll connect via esys later and dbl check which module it was in on mine. HTH.
That’s definitely the thing I want to sort. I too fell for the sales blurb trap of thinking EBT was just another USB and a charging plate.
Yep, think dealers/bmw probably embarassed by how limited non-EBT functionality is and don't want to mention limitations.
But very easy to code in and resolve. A ten minute job with e-sys and an E-net cable.
17 minutes ago, O5carBrav0 said:
Do you know the coding required using BimmerCode?
Change the following in HU_NBT all to Active
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
REMINDER_TRIGGERS_EIN_AUS
MACRO_PIM
OFFICE_MENU_ENABLE
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
OFFICE_MENU_ENABLE
Superb. Thanks for the info!
Will this enable 2nd Phone to handle calls too?
Don't think it does tbh. Worth coding in and trying. If not go back into expert mode and look under that submenu, think it will be HU and then 3003. Should be something like additional or multi phone.
I’ve managed to get it working (somehow) thanks for all your help.
i used BimmerCode and a vGate pro 4 from Amazon.
I’d already activated the BLUETOOTH_2ND_HFP and I’m not sure why but it didn’t seem to work. I the. Set all the features for EBT you recommended and it is now working! Thanks again for your help!
shame I can’t adjust the heated seat temperatures with the vGate though :-(
I’ve coded the enhanced Bluetooth using the settings described and it’s all working fine so thanks for that!
I also tried the BLUETOOTH_2ND_HFP option but this hasn’t changed anything.
Any thoughts on how to get the additional telephone option working?
Joe
Joe
I just did all the listed changes in Expert mode and it worked. It’s not very clear at first when it’s active, I had to delete both the phones and then re-connect them. You should then get the options of Telephone and Additional Telephone..
You can then use the voice control to “Swap Phones” say at the weekend - so that it uses your personal one to make calls instead of your work one.
I tried deleting the phones and turned Bluetooth off and back on, deleted the car from the phone and then readded from scratch but I still don’t have the option of additional telephone.
These are the settings I’ve already added:
EMAIL_EIN_AUS
SMS_EIN_AUS
CONTACTS_EIN_AUS
CALENDAR_EIN_AUS
TEXT_NOTES_EIN_AUS
AUDIO_NOTES_EIN_AUS
REMINDER_EIN_AUS
TASK_EIN_AUS
PIM_BILDER_EIN_AUS
MACRO_PIM
OFFICE_MENU_ACTIVE
And
BLUETOOTH_2ND_HFP
Have I missed any?
Joe
Update to this.
I had another look at the settings and confirmed everything was still set to active.
So I had a look through what else was there and found 2 items which were set to “not active”:
“BLUETOOTH_HANDSET” and “TWO_PHONES_PARALLEL”
I set these both to active and I now have the additional telephone menu option and have configured 2 phones which is working.
Not sure which one fixed it, although it would seem the “two phones” is the obvious one?
Thanks for the help.
cheers
Joe
Edited by JDX-90
What piece of kit do you need to connect to the car to get to this information?
BimmerCode app on your phone and an OBD adaptor.
The App tells you which to get for maximum support - I can’t do Heated Seat adjustment as an example but did do this amongst other things like adding a digital speedo on the bottom trip display etc.
This is what I purchased...
Vgate iCar Pro Bluetooth 4.0 OBDII Scanner for Android & iOS Works on All OBD2 Vehicles (1996 onwards in USA) and EOBD Vehicles https://www.amazon.co.uk/dp/B07GGVLRWF/ref=cm_sw_r_cp_api_i_cLPWCb2WMWQFS
Edited by O5carBrav0
Spelling
You can, you just need a newer adapted
