jags53
E39 M5 2002
Edit: Sills have been repaired.
2002 BMW E39 M5 – Le Mans Blue
Date of Registration: 09/01/2002
Mileage: 132,500 (will go up slightly)
MOT Expiry: 10/02/2019 (No advisories)
Reg: M5 DFF (Private Plate Included)
Hi all,
Unfortunately for me - the time has come to put my beloved 2002  Le Man’s Blue E39 M5 up for sale.  It’s a reluctant sale, but I have a growing family and needs must – It has been a true weekend car having only covering 12k in over 4 years.  Mechanically it wants for nothing and no expense has been spared, has tons and tons of receipts. When I purchased it in 2014 I had Phil from CPC check it over and he was very complimentary of it, stating it was one of the best examples he had seen in a while.
Full Service History:
Service History backed up by a fully stamped service book and tons of invoices – no expense has been spared on this car. Next service will be an Inspection 1.
Service Type
Mileage
Garage
Date
Running in Check
1,036
Holland Park BMW
19/02/2002
Oil Service
12,639
Holland Park BMW
30/10/2002
Inspection 1
29,706
Holland Park BMW
03/02/2004
Oil Service
39,815
Holland Park BMW
31/01/2005
Inspection 2
53,634
BMW Specialist RW Weaver
14/06/2006
Oil service
66,835
02/05/2008
Oil Service
81,929
Douglas Park BMW
05/06/2008
Inspection 2
98,631
Douglas Park BMW
01/06/2011
Oil Service & Vanos Timing, Rocker Gaskets
104,101
Mr Vanos
27/03/2012
Oil Service
107,516
M3 Motor Co
14/12/2012
Inspection 2
116,054
M3 Motor Co
06/02/2014
Oil Service
123,783
CPC Engineering
19/02/2015
Inspection1
127,092
Biddenden Motor Works
10/03/2016
Inspection 2
129,860
31/05/2017
Oil Service
132,586
19/10/2018
Maintenance:
In my Ownership:
·        New Front wheel bearings
·        Inlet camshaft sensors - both banks (Exhaust sensords already replaced with revised BMW part)
·        Bosch Oxygen Sensors pre-cat
·        Washer pump replaced
·        Bonnet lock catches and cable replaced
·        ABS ECU – refurbed by BBA Reman (lifetime warranty)
·        Abs pressure sensor replaced
·        Battery replaced
·        Final Stage Resistor
·        Resealed Rocker Covers by CPC
·        Replaced n/s upper tc arm
·        Replace n/s/r lower balljoint
·        Remove Heater duo valve and impeller (recommended by Phil CPC)
·        Airbag recall from BMW
·        ECU Blower unit replaced
Previous Ownership:
·        New Shocks (Bilstein), Springs and Top Mounts.
·        New rocker cover gaskets (Resealed by CPC in 2014)
·        New Crankshaft Oil Seal and Oil Cooler Seal
·        New Clutch while Crankshaft Oil Seal being done (done in 2012 Est mileage 113,037)
·        New headlights due to condensation in old ones
·        Led interior light kit, Led angel eyes.
·        New windscreen due to chipping.
·        New Powerflex thrust arm bushes so no shimmy/vibration through steering wheel (Fitted in 2011)
·        New ribbon on dash to repair missing pixels
·        Wheels refurbed; have few marks due to clumsy tyrefitters
·        New auxiliary belts.  (12/2012)
·        Thermostat and seals (2011 Est mileage 100,000)
          New Power steering hoses and reservoir
Plus lots more, but i have tried to list most of the major ones above.
Modifications:
·        Backbox delete – may not be to everyone’s taste, but genuinely sounds lovely and does not drone on motorway
·        E60 shifter – this can be a bit notchy in the colder months, therefore I have a brand new original shifter ,which will be supplied with the sale.
General Notes:
Body:
It is a 16 year old car so does have the odd small ding/scratch but nothing significant.  Unfortunately, it does have some bubbling appearing on the driver side rear arch.
One of the parking sensors may need to be replaced also, as its constantly beeping in reverse :S
Have x4 Winter Kumho winter tyres, which will also be supplied.
Interior:
In Excellent condition given the age of the car – all electrics works as they should
Price: £10,750 ONO
Contact:
sandhu.jags@gmail.com
07402074660 - Please text before calling as most of the time i cannot answer my phone.
Photos:
IMG_8446_zpsfd43ce42.jpg&key=11007871855
IMG_8430_zpsf5318b38.jpg&key=3474aa606c8
IMG_8414_zps63f3173a.jpg&key=d575e78de75
IMG_8367_zpsa4d17a19.jpg&key=cdfe5cf01bd
IMG_8330_zps4e81b045.jpg&key=e32e54be634
IMG_8315_zps08b307ff.jpg&key=db6483f3e67
IMG_8299_zpsf990e822.jpg&key=95078913d30
IMG_8394_zps8bbb6577.jpg&key=f50a1b0bf99
IMG_8585_zps2b3d007d.jpg&key=26a4ccc90a6
IMG_8573_zpse44ff730.jpg&key=c18487fa3da
IMG_8549_zpsd6a6eaa9.jpg&key=c2e4c7f1a14
IMG_8365_zpse140f666.jpg&key=9b9f89f28e6
y4mXXtmm5ej4SXajsUnv2VR-xvs1KyXrhKKTJ7yj
y4m36WRACoAijQqNqvQLn3GlzTjMZaPRgoTJ1dua
y4mUOAxwrQLbbRL917pIRrRrRXSoDC37qSf5hqri
y4m_yfrtLSd1Qn0-4ny2D9myBs8S36pmfJLPKTgb
y4m1b54MOaGQuZQKBZMPlRS-RtitaIzxB8NjZkQG
y4muHFao3rXmmejj4z9KhK5mCTmEgao2auAmdcbn
y4mVtWnrU-asswdHeMUeNz2Lz2dIV22GUfLg6mYn
y4mB8C61QSe0B28EYdfA1-09EX_NNY8Q6tUPaSkl
y4m7A3v6D0sAtQGVTuCbVixDmvKkQmnbYnhr3dX_
y4mKADDOwCcPBGZQAyG7_TpUAw3ViYTnJdaH-vlu
y4mbt9-RQtvOLcjKd4-yyPbY5sL6KhpXaOYbTndX
y4mhiyk8xhwlDTrtbX6Rou_zrB7QJDItop9SfI43
y4mSsQgTjwuguZOH67nL0cP0J_15_nZsvZjjDnoZ
y4m16cwcXGPdV9hDivAxzRIQvz2n8wpPRshGF3KW
y4mfId0piBt9XAFhhULgWBxqsTCM6w_4K1xithms
y4mK2LRmD1pBoa9DNVmFJ4edzG7Y6IScXeRtt1IP
y4meIFeTbI4Cui61rWwJuFjyDeGDfXSTg8f8eLKf
y4mgS1viQEh0lMqG6MrGjxl2BS3VjapHlxJDccTu
y4mpVweQ01AhfuP_nWPUcd1kNNUZWCXt1znWx4QB
y4moI3A-5lVbq2bRbSyffypXQF-_zmkQacVlIfXT
y4mR1MOZ4JloLWx8JWl1r5eIrl3JO7eg4hMFYiDn
y4meP5NEpkeamsstvzfKT55ODuieq8W7UVhaZnHN
Edited by jags53
@rbond9 - I've edited your post to highlight jags53's name; he'll get a marker at the top of the page when he's on the forum next. You can always PM him as well; he'll get an email notification then :)
Thanks Dan, I have PM'd him and we are trying to set something up.
Can I just add that I had a chat with @jags53 about his car leading up to the discovery of the work now needed. He was totally honest about any issues with the car and hence removing it from sale which shows real integrity that is often scarce when buying a car these days.
Edited by rbond9
added tag
Bumping this thread as car back on for sale - sill repair work has been completed - pictures of work are available for anyone who is interested.
