Gingerninja
Oil pressure warning
I'm have trouble with the oil pressure warning popping up had oil pressure test came back fine changed the switch and still the same problem no change in oil level checked daily since its started any ideas would be helpful thanks
Are we talking oil pressure here or oil level - or maybe both since you mention both? Apologies if I'm teaching Granny to suck eggs, but there's often confusion when it comes to dashboard warnings. A low oil level will only cause low oil pressure if the level falls below the oil pump pickup in the sump. Although I occasionally refer to the iDrive oil level reference I rely on the dipstick. Engine needs to be normal running temperature, switch off, leave 5 mins then check the level. I normally dip mine twice as the first time I pull the dipstick it invariably reads low or even nothing. Dipping a second time gets the heart rate back to normal.
A flickering oil pressure light at tickover on a hot high mileage engine happens, but presumably you're not in that territory?
Let us know how you get on. :)
