arron9999
need help asap knocking in suspension
hi all
I am going away to Europe in 2 weeks and have a knock from the from end passenger side what sound like ball joints.
I keep chasing it and have replaced a lot of parts but each time i does it either stays to same or seems to get worse,
so far i have replaced
inner and outer tie rod ends
control arms both from and back
anti roll bar links
anti roll bar bushes
strut top mounts. I have also re torqued the strut bar.
I dont know what else to change or check, im going to have to bite to bullet and take it in unless someone has any other ideas.
Car is a E61 535D LCI
Thank you
Arron
there is only the lower 2 as its on the front 11 and 16 on both sides. haven checked the shock though didn't know it would cause that. but thinking of it could be
Edited by arron9999
One is the tension arm and one on s the control arm
Tension arm is the front arm which goes downwards into the steering knuckle.
Control arm is the rear arm which goes upwards into the steering knuckle. It was the control arm balljoint that failed on mine with a corresponding clonk from the front end.
New arms and noise went.
How is your tension arm?
From what you say you have near enough replaced everything assuming you have done both tension and control arms on both sides.
The only things left "old" are the spring and shocker.
Other than the clonk it must handle like a new car.....
The bushes in the lower control arms are a common weakness on BMW - even a pry bar test doesn't always show them to be shot, until you actually remove them.  It is sensible however to replace both the control and tension arms together.
19 minutes ago, arron9999 said:
hi all
anti roll bar links
Thank you
Arron
Drive it over MOT station pit whilst someone checks below. I did the above plus new shocks & springs, it turned out to be the driver seat base!!
4 minutes ago, Dotcom1970 said:
If you have replaced those, then as @535i Andrew says, it's either the shock, spring or top support bearing.
He's done the top mount which really doesn't leave much that could make the clonk which is why I am struggling to suggest anything.
I can't see the spring making a clonk unless it's broken but that would have been obvious on top mount replacement. Can shocks clonk? The E60 has a solid non bushed connection from the strut to the hub which wouldn't cause a clonk. New top mount shouldn't clonk.
Unless @jake13 is on the money....with a bust seat.
Thank you all,
yes the tension arm has been changed on both sides and also the top strut mount.
The car does handle fine but when i knock/rattle happens i do feel it through the car and also the steering wheel.
very good write up, wish i had found that before i had done all the work as that would have helped loads.
The noise is most defo from the front, I have had my old man in the car listening for it while driving and is almost 100% in the location of the front wheel.
Search on here or post with symptoms before changing out loads of bits.....he says in hindsight:ph34r:
Been there done that on my old E39, hence why I changed them immediately on my E61
33 minutes ago, arron9999 said:
Thank you all,
There is a bracket which connects the anti-roll bar links to the hub. I got 'carried away' when trying to remove the shock from the soft aluminium hub. This made a clonking sound until I retapped the hole and put the bolt back.
Edited by jake13
Photo 11 in my link above, the one with the socket over it?
What were you doing to get carried away?
To seperate the strut from the knuckle drop drop the whole strut out from under the wing then separate on a bench.....
Nearer the end of this post I dropped the whole lot out. Sooooo much easier!
Giving the hub/knuckle the kiss of death with a 3lb club hammer. Spending all day and the meter running for the lift (£10/hr), Mr Hammer was the only friend I knew.
Been there.  First time I used a big Allen key and a flat bladed screwdriver to prise apart the knuckle while my dad hit the bearing assembly with a similar sized hammer. We were replacing the bearing so that was o.k. But it put up a real fright. If you are resorting to hitting a BMW then you are doing it wrong. You shouldn't need to hit anything to get it apart.....but it is more satisfying  ;)
Next time I removed the 3 nuts in the inner wing and drop whole thing out from under the car.
I was going to say the engine brace bar that goes between the top of the struts and firewall, if they're lose they knock..
Glad it's sorted
Glad it's sorted
I'm toying with the idea of something like this
http://www.ultraracinguk.co.uk/ultra-racing-front-strut-brace-tw2721_p26384964.htm
Had a similar thing fitted on my old Volvo V70 which vastly improved the cornering feel
