cwat
abs lights etc
Hi got the abs,dsc, brake waring lights coming on Have changed abs sensors one on front and one on back and changed over the old ones The lights come on after moving about .5 to 1 mile then a little while after it comes up tyre control inactive can someone tell me where to look next  Thanks
Just happened on my E39 M5 and it was the ABS control module.  Exactly what Jag says.
Really? Didn't realise wheel bearings had any sensors? They are not cheap on the m models - I would suggest getting a second opinion if possible
Hi I always thought the sensors read off the back of the bearing on the front so if you got 2+mm ply over a distance you would get a wrong reading cant see what the sensor can read off if not that  i could be wrong
I believe that there is a sensor which look at the speed of front and rear wheels and if this goes you need to replace it as the speedo stops working, sure that was on M5 boards.  I will see if I can find the article and post it for you.
