Adam206
Inpa reset issues, no throttle?
Hello everyone!
Sorry to be that guy but this car now makes me want to cry! I had a small hiccup and after replacing a few items, I thought I would reset the adaptives, silly me!
The car is a 525i N53 07 and I think its an LCI too?
Now I have no throttle, checked the harness, connectors, replaced the throttle and even had the ecu reflash to no luck!
Has anyone had a similar issue? And found a fix?
Regards
Adam
What parts have you replaced and what did you reset adaptations on?
Sometimes things can get suck in a loop I had this when I flashed Speedo and car would start but Speedo was dead I disconnected the battery for hour or so reconnected and all was working.
Failing that is there any error codes?
Have you tried resetting them again?
Ps: not on all cars put put ignition on so dash lights up but don't start car try pressing accelaretor peddle to floor 4 times then turn off for minute and then try and see if it works
The above may or many not work for your car
Edited by khile
Hi & welcome.
20 hours ago, Adam206 said:
...even had the ecu reflash to no luck!
Sounds a painful experience :(, hope the forum can help you find a fix soon.
