Modge
E60 CCC Android system upgrade
I was googling for android head-units and found this topic...
First of all nice retrofit job Misterbish! I've ordered same unit from same Ebay seller. Arrival time was about 3.5 week.
I've just finished installation and got a problem with sound from unit - there's none. Do you have to connect two aux rca's to your car aux somehow? there were 2 rca cables- red & white. Factory CD/FM/Aux sound works fine. I've followed a guide from some blog, but described unit was slightly different hence my question.
Everything else works perfect, including backup camera.
Hi
No I didn't have to connect anything other than the multiplug extention lead that came with the kit, also had to relocate the most optical cable (green/black) from the oem multiplug to the new multiplug extention that then connects into the back of the ccc unit.
Aux volume is very low on startup, did you crank up the volume while in the android dashboard.
Thanks for coming back so early!
I'm pretty sure everything is connected correctly including optical fibres.
I think I found solution on some Spanish boards (hallelujah google translate). I'll leave it here for next visitors, in case they will encounter same sound problem. From what I read, this problem exists if your car running professional CCC or both USB/AUX interfaces in armrest.
Solution 1
No sound in Professional CCC Browser 8 buttons -> set the AUX function to "mount" in the CAPPL module with NCSExpert and NCSDummy.
Solution 2 - tested and work
Use RCA to Jack 3.5 and connect to car Aux - in my case it's inside armrest.
I ordered RCA to Jack cable from Amazon, so I'll give it a try tomorrow.
Another tip I found from Spanish boards is to connect to OEM GPS antenna, the one included in kit takes ages to connect/locate if you place behind unit - I've tested this morning and can confirm that it takes up to 5 min to connect. Apparently you can use Fakra to SMA cable, doing so you will loose connection to OEM Nav. You can also get a Fakra splitter to multi connect both Android unit and OEM Nav.
Yet another tip is to use anti glare screen protector. I've just ordered mine from here https://www.amazon.co.uk/BROTECT-Screen-Protector-iDrive-Navigation/dp/B01CV4QYLG
Edited by bimmer_ldn
I used the default GPS antenna and mounted in the passenger side a pillar, i kept the oem one connected for the CCC unit incase i need to use the oem sat nav, mine doesn't have any connection issues that i have noticed.
Good find on the screen protector i have just ordered a couple.
Let us know how you get on with the RCA jack cable, if it will solve my low volume on startup using AUX i might go down that route
I tested RCA/Jack to Aux connection, works good! Haven't noticed problems with low volume on startup I feel like everything is on similar level.
I still have to change GPS connection, this morning external GPS couldn't locate position at all though it did manage to sync time. I'm not using OEM Nav so I'm not going to miss it.
Edit:
My screen protector arrived Today, it really helps to reduce sun glare on screen.
When fitting, take of the plastic cover - it's fixed with 6 screws. Makes the screen protector installation job much easier.
new stuff
On ‎12‎/‎04‎/‎2018 at 5:08 PM, Misterbish said:
Navigating isn't a problem its only a few sub menus that i find you have to use touch screen, the rest i use the idrive knob, i also upgraded my idrive controller to one with the shortcut buttons off a LCI, makes it a lot easier.
Hi, slightly off topic question. Does the LCI controller with the shortcut buttons work on the OEM CCC??
Monkey
Yes it does, requires a little wire modification, i had to update a couple of modules on mine to get it to work, the worst part was cutting out the larger hole in the centre console trim to fit it.
But well worth it....
Good news! I found your other thread on doing that.
Also found a guy on German eBay that will machine out the trim to the right shape.  Although the thought of cutting the original M5 aluminium trim does make me cringe. Also can't find the right button combo for the full LCI console swap. They all seem to have DSC where I want the tyre pressure warning button
Still not managed to get mine yet, been spending too much money on my bike!! I see there are now ones running android version 7 now, so glad I postponed, will hopefully get mine next month.
Had a little play this morning seeing as it pissing down outside.
I ordered this a couple of days ago
LINK REMOVED AS FAULTY
Now i finally got Torque app to work, with this OBD adaptor its really quick to connect to the car,
Customisation options are almost limitless, i have been wanting to get this to work since i installed the the android unit and we all know how important it is to keep an eye on our coolant temps.
Ignore my engine temps the engine was started from cold and left idling while i setup the dials. Its not a true representation.
Edited by Misterbish
Cant spell for shit
Apologies to OP for the thread hijack but seems the best place to ask?
Has anyone tried getting Apple CarPlay to work on the Aux input on the original CCC unit?  The Android head unit allows you to specify an Apple CarPlay dongle which I assume has the requisite software loaded?  Surely this coupled to an AUX or RCA input would allow Apple CarPlay to be displayed on the CCC unit?
So i had to remove the link to the first OBD Wifi adaptor i bought as when i went to use it the next day it wouldn't work(cheap Chinese crap)
Bought this one instead and all seems to be ok after 3 days.
My next job its to get root access to the android head unit and see if i can find/customise the app that's linked through the Car Info shortcut. at the moment it shows car's speed, engine revs, actual fuel level and indicates if a car door is open(designed for LH drive as doors open opposite to ours), so it must be getting some information via the ECU/OBD already, if i cant find a way to customise it at least i will know the apps true name and see if there is an updated better version we can install.
Installed it today. Fairly straightforward, I had to remove some clips from the big multi plugs before they would fit. Getting them to hide behind the cd/dvd player again was a pain in the arse.
 I fitted a screen protector that has an annoying bubble in one corner, looks fine when in my hands, only shows up when installed. I'll redo that another time. It didn't help much with the sun's glare though.
The std android keyboard is an absolute pain in the arse to use, Swiftkey made a massive difference. The std BMW Idrive homepage doesn't display correctly, everything else is okay though.
The volume is great on it, pull down the top of the screen and there's an additional volume control that should sort any issues you have.
Just need to sort out steering wheel controls and voice control would be nice when searching for apps or addresses in navigation.
Waze and Carly downloaded, still need setting up
Edited by Deviant
Deviant - Thinking of doing this mod myself so keen to hear another point of view of the user experience.
I'll add some more thoughts once I get everything sorted. Adding an SD card with music will be the main benefit for me. I want an mp3 player that can browse folders, so you can listen to other artists or genres easily.
I watched a trailer for Furious 7 that came with it and the display was very impressive. I can't envisage me sitting in a car watching movies, you can't really have it on while driving and you'd probably start having
battery power concerns if you did.
I'm adding google music and Amazon music apps to try out. There's no radio in the GUI menus, there may be a widget or something I haven't spotted or you may have to go back to the original I drive and use that.
I don't listen to the radio much at all, but seems odd it isn't there.
Male to female USB leads might be useful if you buy one so you can extend them to the glovebox to access a USB drive or an accessory without having to strip everything down again.
Edited by Deviant
Oh crap
Until today the unit has worked flawlessly, this morning how ever it is stuck on the BMW logo screen and I can not find a reset button to restart it. The screen works fine original ccc screens are OK and reversing camara is coming on, it's the android dashboard that is frozen.
I have emailed the seller on ebay and eagerly await his reply
5 minutes ago, Misterbish said:
Oh crap
It'll probably be one of the pinholes either side of the sd card slot on the left of the screen
Edited by Deviant
I thought that, bottom pinhole is were the mic is and the upper most pinhole is empty, I took the unit out just to be sure, I can't find a little reset button/switch anywhere.
