Biotoxic
Yet another 535d project thread. High mileage daily drive.
Hello there,
2005/3 E60 535d Msport automatic in Carbon Black.
I always wanted to do a Project thread regarding a BM. I've seen a quite a lot of ''Project threads'' here and elsewhere mostly without any pictures or in-depth explanations or just a dead end threads. Hopefully, this should become one....
So then... I got this beauty advertised on Gumtree as a high mileage one(192k miles on it at the time of purchase), so it was a cheap one, just 3.5k.
Since I am not afraid of a high mileage cars I opted for this one instead of 2008 E60 530d LCi.
The guy that I bought it from used it mostly to get to work in Dublin and Belfast and since he is living near Newry, he did a quite a lot of motorway miles. Just to make sense why I chose this instead of LCi was most of the distances he traveled.
Just to make sense of it:  If I had a choice to buy a lower spec car from somebody out in a country and a car, that has mostly been used at the town/city with higher spec gadgets and gizmos I would choose the one that is at the countryside every time. Why? because of:
1. It's a diesel! It is supposed to be used on longer journeys to be more economical than the same capacity petrol engine. Since I do a lot of miles myself this is why I went for it.
2. It's a diesel! It clogs up if you drive like a granny on Sundays after a church mess on your way to see the relatives/friends while doing 20-30 mph and an A-class roads where the max speed limit is 60.... Since this doesn't apply to me as I am on a motorway for a most of the miles to get to work, I don't have a problem with it. Diesel needs to be driven harsh once in a while to burn off the soot and other deposits from inlet manifold and surrounding areas. If you're doing less than 8k miles a year, diesel is not for you!
3. It keeps me busy. I wouldn't know what to do If I would buy a brand new car. Changing oil is easy, but I am looking for a challenge so a new car is a no-no for me... I like to get my hands dirty once in a while and the feeling after ou get when you fix something yourself.... Those who know what I am talking about, they will understand.
4. I can fix stuff, I can change it if it needs to be changed and I am not too sure how to do it there is that wonderful thing called ''Google'', but it needs to be master as well as not everything you see or read on there is true....
5. I always wanted a Black BM with beige leather seats!
6. A bit more about myself at the ''Hello, I am new here'' section
So there it goes, a bit of intro with a story and pictures and then straight into the stuff I have done so far.
At first, it looked black on the advert, but whenever I went to see it for the first time it was actually a Carbon Black. Whit a lovely beige interior, a perfect combination in my opinion.
When it's dirty or depending on sunlight conditions, it looks blue-ish or gray-ish.. (camera doesn't reflect the real color)
At the Terraclean Co Down
Since there is a character limit per post(but it is not displayed) I will continue in next post.
Whenever I got the car, it came with additional extras, but they weren't fitted and they were sold/bought separately. If the previous owner would have left the audio system in, I would have fewer problems now...
This is what I was left it to figure it out...
So I got a Dension Gateway, TV module, rearview camera, 16:9 Professional navigation, car audio amplifiers and other bits and pieces removed from the car before I bought it..... No idea why...
Anyway.. I have done a simple audio installations before. Generally, a head unit has a RCA output ports,  usually 4 of them. Connect it with a amplifier, add a Remote wire from a head unit to the amp(so a head unit can switch on the amp whenever the ignitions is on) Route the Speaker cables to the speakers, to get the better sound over the original wires(more hustle, but way better quality sound) Route at least a 4gauge positive and negative cables with car's battery to the amp to power it and in short... there you have it, a basic 4 channel audio installation.   BUT in E60........ NO, YOU CAN'T DO THAT..... Audio system works with a fiber optic cables, System is called MOST. If one of the modules malfunctions or if there is a break/damage or it doesn't terminate where it is supposed to either the whole system(ring token type doesn't work or it's glitching.
Anyway, I got it somewhat sorted and I also managed to route most of the speaker cables to the speakers.
What a mess...:huh:
Most of the times I have installed just one amplifier, but now I got three... but it turns out I also need a thing called DSP Digital Sound Processor CONDUSEDdotCOM :blink::huh:
Rear seats removed, routing audio cables...
Dension gateway access used to be a replacement for the CD changer(it emulates CD changer in order to play music from the aux in for example) but it still needed to be connected to the loop... Following instructions were.... inconclusive... managed to figure it out watching few youtube videos B)
A multimeter is a must!
So after a few days of doing my head in it looked like this:
at the end it looks like this:
Somewhat tidied up a bit, but nowhere near finished. Still a long way to go. At least I have some sort of audio now, but it's not on my priority list at the moment.
The other thing I noticed about the car was a strange look of the intercooler. I will return to this later on..
Right. Next step on my list was to check the condition of the inlet manifold.
yep... carbon.. its there, but not as much as I thought it will be.
the actual lower air inlet ports weren't too bad, the top ones, on the other hand, were way worse.
so after I removed the inlet manifold itself, I put it in a bath for overnight... :rolleyes:
I used ... I can't remember the name of it, but it is some kind of acid, but you can get it from Asda from around 1 quid, be warned, don't use it on aluminum, it dissolves it.
after a lot of rubbing and cursing, I managed to get it cleaner...
Edited by Biotoxic
Mostly cleaned
New seals fitted
Inlet manifold from the inside, something from the Game of Thrones... :D
That was as best I could do, but there is another, less messy, easier way to do it.
This is how it looked, but I used an engine rebuild workshop and asked them to clean out. There are two ways hot to do it. It's either using a chemical bath or using an ultrasonic bath. I prefer the last one, the results are amazing :o
E46 320d valve cover with inlet manifold.
A perfectly clean inlet manifold! I would suggest if you do it, then remove the valve cover as well, as the most soot stuff are stuck on the plastic bits. I did both parts at the ultrasonic bath. Cost me £50 but well worth the money.
This is how it looks when removed from the engine. I would suggest changing the glow plugs(perhaps a glow plug control unit as well if there are any errors while diagnosing DDE) vacuum hoses, de-flap it and remove valve cover(as the valve cover gasket will leak eventually.... So most of the stuff can be changed while the air inlet manifold is off. Valve cover before manual cleaning.
After the ultrasonic bath. Well worth the money!
Valve cover with a new OEM gasket. E46 320d valve cover after being ultrasonically cleaned .P.S. remove all the parts from the cover and/or inlet manifold before you sent them away from cleaning. All the bolts can be removed and you have to remove them before cleaning takes place.
Also changed the oil and and the filters as well, it just makes sense.
On 20/08/2018 at 15:29, oldjohnny said:
Was the stuff you used from Asda soda crystals?
almost a year late, but no. No soda crystals from asda.
3'' exhaust from powerflow, K&N replacement filter, changed the boost pipes and boost sensor. Did a carbon clean and stage 2 remap. that is shortly after I changed those thinks + full service.
Both boost hoses were old and the lower one had a split in it. I used duck tape to temporarily fix the problem
thumb_show.php?i=zens4mnu
Changed the temperature sensor as well as it had a ''0'' resistance
thumb_show.php?i=qkcsq5y6
Can't complain about them.
Also, noticed a leak from the shut-off/anti-shudder/butterfly valve. Got another one(one the right) from the local scarp yard. Tested on site using ISTA, it worked fine so I got it for £30
thumb_show.php?i=cascnuc6
Since I have the straight exhaust pipe I also need a DPF to pass the MOT. Managed to find an empty one and one from the 2.5 diesel. Since they have a few different sizes I need to improvise...
thumb_show.php?i=7nen2pjp
Shortly after dealth with an oil leak from the small turbo return pipe, turns out the gasket was not secured enough when I got the small turbo refurbished. You can see it how it was put on...  more or less 40% of oil return pipe was blocked with a gasket itself...
thumb_show.php?i=z7tc9jnr
and got this .. mess.. sorted and relocated.
thumb_show.php?i=3jntxt8k
Had to change the brake disks due to vibration when braking.
 thumb_show.php?i=sjqjngkf
Opted for performance brake disks(high carbon content) with a Mintex yellowstuff pads
It's called the C-shape aka as few my friends call them, the fish hooks :D
thumb_show.php?i=7dee5nd5
thumb_show.php?i=qa9vkv6z
  front brake pads weren't too bad but the rears definitely needed changing.
thumb_show.php?i=6ehh7yru
Also bought an undertray/mudguards as the old ones were damaged
thumb_show.php?i=awnhuyau
Experimented with a marine grease on the wheel hubs and brake disks where the alloy attaches to it to stop the oxidation and be able to remove the wheel easier next time it needs to be removed.
Marine grease on one side, WD40 on the other. I will update this after next winter whats better in the long term.
thumb_show.php?i=nwygwwjf
thumb_show.php?i=4g8t88ba
Also changed the diesel fuel filter and cut it open just to see what's inside...
thumb_show.php?i=u4h8e988
thumb_show.php?i=upcv8qvj
thumb_show.php?i=whk7xa43
thumb_show.php?i=kpafqtf9
The filter element is made out of paper with a plastic insert to stop it collapsing on itself when the pre-pump/pump is activated.
thumb_show.php?i=z9r6929f
thumb_show.php?i=wdf9wmwa
It was previously changed more than two years ago, no visual debris or dirt was on the filter. BP ultimate diesel is worth it.
Edited by Biotoxic
Fixed links so images can be seen
22 minutes ago, Biotoxic said:
fixed now
Some good work there; who's brake discs are the C Hooks; Mtec?
I use the EBC Yellowstuff pads; big fan of them. Dusty when used with grooved discs etc, but superb stopping power 8) Just make sure you bed them in properly ;)
Mtec indeed. I changed the brake pads and disks a few months ago, now its all bedded in properly.
Edited by Biotoxic
