Medved77
Roof Discoloured - Advice Please
Looking for some advice as to how to restore my roof on my jag xj8 to its former glory.
I'm not sure if it's clear from the picture but it looks cloudy like water has sat on it then dried.
I've used clay bar, polish and wax but it didn't make a difference.
If you compare it to the 2nd image of the bonnet you can see the difference in colour.
What products/processes can you recommend?
I would suggest machine polishing starting of with something like chemical guys v34 then v36, if v34 isn't cutting quite enough you could drop to v32. I had good results from these products, search on YouTube.
Thanks, will check out youtube. I have an orbital polisher so hopefully that'll do the trick.
No problem, that will be ideal with a hex pad and the above polish, also when you do it tape off part of the roof so you can see the difference.
Let me no how you get on
