supertramp101 87 Report post Posted December 28, 2015 hi has anybody got a solid state harddrive attached to intravee and if so what is max size ? thanks all st101 Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted December 28, 2015 Connect how?Using a KCA-620m, about 1Gb is all you can reliably navigate.Using a KCA-420i, the 128Gb iPhone 6 will work, with the relevant adapters. I have an iPod mini that I replaced the standard 6Gb micro drive with a 32Gb Compact Flash card, works fine, not sure if you could go bigger, 32Gb was pretty expensive when I did it. Share this post Link to post Share on other sites
supertramp101 87 Report post Posted December 29, 2015 thanks richard for the reply how ?iam still working on the best way but have plenty of computer bits and cables laying around including an internal cold swap 2.5in hard drive caddy but probley easer and cheaper to connect 128 gig stick or card via a usb card reader this is assuming i can connect via usb or should i just buy i pod all iam looking to do is have something perment and hid away and only removed to change the music on the media or iam i out of the park with this Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted December 29, 2015 The Alpine USB interface, which is the only way to connect USB to the Intravee is total crap. Unless you are a masochist with a small audio collection, use an iPod! 1 Neilb reacted to this Share this post Link to post Share on other sites
supertramp101 87 Report post Posted January 1, 2016 thanks richard will do which i pod is the most compatable ? i take i can load it up and tuck it away someware i think i read someware only some will charge from the lead is this correct? Share this post Link to post Share on other sites
Rich_D 207 Report post Posted January 1, 2016 I had a 30GB iPod 5th gen that lived in the boot hidden away, that is a LOT of music, worked perfectly with the Intravee, older ones are better for leaving in the car and no charging issues Share this post Link to post Share on other sites
Angrydog 236 Report post Posted January 1, 2016 I use a 60gb iPod 6th gen - works fine. 1 Rich_D reacted to this Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted January 1, 2016 The 'best' iPod to use is the Gen 5.5 Video 30 or 80Gb, the next best is the Gen 5 Video, next the Classic (Gen 6). The Gen 5 and 5.5 have the black or white flat plastic front with colour display. The 80Gb Gen 5.5 can be upgraded to 240Gb by swapping the hard drive. The Classic has a bug that means once in a while it will lock up when you stop playing, it does this with all iPod interfaces I've seen, including the BMW USB interface in my M6. The Gen 5/5.5 uses hibernation so tracks start playing where you left off even after weeks, it will charge from 12V so you don't need a charge converter and they support compilations so you can filter out artists from compilation albums from the Artist search. The are also pretty rock solid software wise. 1 Rich_D reacted to this Share this post Link to post Share on other sites
supertramp101 87 Report post Posted January 3, 2016 right thanks all i think now have a picture of what i want to do now storage wise, looks like the 5 or 5.5 is the one to go for as i want to fit and forget it think 80g will be plenty of storage st101 Share this post Link to post Share on other sites
ccfj1 5 Report post Posted January 21, 2016 I've just fitted a 32gb ssd zif drive to my spare (clicky hdd) 30gb Gen5.5 and it work perfectly if thats any help, the 32gb ssd was £28 delivered. Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted January 22, 2016 What drive did you get John? Share this post Link to post Share on other sites
ccfj1 5 Report post Posted January 22, 2016 (edited) This one. 32gb = £28 postedhttp://www.ebay.co.uk/itm/181186447463?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT But the others available. 64gb = £40 postedhttp://www.ebay.co.uk/itm/1-8-ZIF-CE-SSD-64GB-for-MacBook-Air-1st-Rev-A1237-DELL-D420-D430-HP-Mini-1000-/181173927664?hash=item2a2ecebef0:g:l4oAAOSwrklVbDEf 128gb = £50 postedhttp://www.ebay.co.uk/itm/181186447463?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT It came in a couple of days and fits perfectly. its the exact same size as the normal hdd and you just swap over the plastic/rubber mounting and thats it. You need to then power up and connect to iTunes and then hit the restore button and Job done. Using it in the car last night and its just the same (but now without the clicky hdd, lol). playlist/artist/album search does not seem any quicker, but thats probably a kca limitation, using the scroll wheel does feel a little snappier though, I did note that the song starts from new playlist select seems quicker, it pretty much starts playing instantly. (that could be placebo though). I know I should probably have bought a larger one...lol Edited January 22, 2016 by ccfj1 Share this post Link to post Share on other sites
Angrydog 236 Report post Posted January 22, 2016 I find mine doing odd things. It'll skip tracks or start a track a few seconds in? Anyone had that? Share this post Link to post Share on other sites
Rich_D 207 Report post Posted January 22, 2016 I find mine doing odd things. It'll skip tracks or start a track a few seconds in? Anyone had that? Nope, never had any issues with my 30GB iPod, I really miss the Intravee, wish there was something like it for my E90 Could be the HDD playing up? Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted January 22, 2016 I find mine doing odd things. It'll skip tracks or start a track a few seconds in? Anyone had that?Could well be the HDD crapping out, unless the iPod is totally dead, the mechanical HDD is the most likely component to cause issues. Share this post Link to post Share on other sites
Angrydog 236 Report post Posted February 3, 2016 Could well be the HDD crapping out, unless the iPod is totally dead, the mechanical HDD is the most likely component to cause issues.Plays OK when I am just using it as an ipod with headphones Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted February 3, 2016 Maybe a dodgy dock connector then, have you tried a different iPod? Share this post Link to post Share on other sites
Angrydog 236 Report post Posted February 3, 2016 No I haven't. I dont own another ipod and I don't fancy buying one to test lol. If I find someone who has one I'll do a test Share this post Link to post Share on other sites
Rich_D 207 Report post Posted February 3, 2016 (edited) Check the plugs are all in the back of the Intravee & KCA-420i properly Mike Edited February 3, 2016 by Rich_D Share this post Link to post Share on other sites
Angrydog 236 Report post Posted February 4, 2016 Cheers Rich, I'll do that when I am back home (working in French France until the 19th!) 1 Rich_D reacted to this Share this post Link to post Share on other sites
Angrydog 236 Report post Posted April 28, 2016 Dodgy dock connector. Tried to update from my laptop tonight and it would just keep disconnecting. It got launched. So I think I am going to get a 5th gen 30gb and then if needs be upgrade the HDD. Share this post Link to post Share on other sites
IINexusII 182 Report post Posted April 29, 2016 (edited) i got a 160GB iPod Classic 6th gen working fine with Intravee (with the always-on wake mod) Edited April 29, 2016 by IINexusII Share this post Link to post Share on other sites
RichardP 1,186 Report post Posted April 29, 2016 The iPod Classic (or 6th Gen iPod) is ok, but the software is not as stable as the 5.5 Gen Video. This is not just a KCA-420i or Intravee thing, I have a Classic in my M6 and it just locks up from time to time, the only fix is to unplug it and re-boot it. Share this post Link to post Share on other sites
