RingsideE34
New owner 3.6 M5
Front suspension now fitted and it drives so much better than before :D no more crashing over bumps, next up im fitting my 535i power steering pump, deleting the SLS and renewing the rear suspension,  will fit my new parcel shelf whilst im there (long over due).
After that ive got plans to delete the air pump,  fit a lighter flywheel and recon the alternator, then a few bits to sort on the interior.  Not sure the to do list will ever end but im still enjoying the journey
I spent several hours of polishing and waxing this weekend, a few pics....
FpR7G1n.jpg?1
dK2yraj.jpg?1
qcPh4h7.jpg?1
UIz8JVp.jpg?2
Edited by RingsideE34
Its been a little while since ive updated this,  things have been a bit hectic but still making progress on the car :)
Shortly after getting the car back together and polished up to enjoy the end of the summer i manged to break the gear linkage :angry:
eVmRp9M.jpg?1
I got this fixed and whilst in there i fitted the shorter of the two E60 545i "short shifters"  which is p/n 373...... i hated it and quickly swapped it out for the p/n 261 which is slightly longer and a huge improvement over the stock feel!
Then the car tried to set fire to itself :angry:
The fuse for the heated rear window melted,  i think i had a lucky escape and the damage to the wiring wasn't that bad, replaced the fuse box casing + a small amount of rewiring....all sorted.  Im now running without the rear heated window fuse and some googling tells me its not an uncommon on E34's and E32's.
I then treated the car to a long overdue tyre upgrade
TVkEn4I.jpg?1
NPL7TV1.jpg?1
I have to say the improvement is huge... money well spent
Courtesy of Dave @ Classic MD Autos i upgraded to Black 3.8 M5 Kick plates,  i think they look much better than the original 3.6 grey items.
The car then went up to Dave @ Classic MD Autos to fit one of his lightened flywheels and various other jobs,  big thanks to Dave here!
As is my luck the sump was diagnosed as having cracked and a replacement item was fitted,   New clutch, lighted flywheel and new rear main seal fitted.
Dave also deleted my SLS
Fitted my 535 PAS pump
And fitted the rear Koni's + H&R
lfXmv1m.jpg?1
converted to a 535 PAS hose/reservoir setup
Also upgraded to a new 20mm Rear anti roll bar
And refreshed the diff oil
I then pulled the inlet off to have a 2nd attempt at getting it painted up nicely.   Whilst inlet was off i addressed some other jobs.....
Had the alternator refurbished
qkmpiIw.jpg?1
Fitted a new Bosch stater motor and replaced various hoses like the brake booster and the some coolant lines.
ymA3m8p.jpg?1
Also added a 12in sub in a small box
That's pretty much up to date,  the car now drives better than ever and the lightened flywheel has made a huge difference,   really happy with the car now  :D.... but still a long list things i want to do in the future...
qkmpiIw.jpg?1
ymA3m8p.jpg?1
qkmpiIw.jpg?1
ymA3m8p.jpg?1
Looking great, what future plans do you have for the car?
I've never met Dave but can say he's always been very helpful to me and has a wealth of knowledge on these cars. If I didn't do the work myself he's likely one of the few people I'd trust to do the work for me.
Edited by Azmontana
Future plans include.....
Take the car back to the paint shop to address some small bits and re machine polish.
Recaro front seats similar to the 20 jahre seats
Redo the rest of the exhaust system and delete the cats
Get the car remapped
Convert to an aluminium radiator and electric cooling fans
Re trim the back seats and door cards
Upgrade the front brakes
Delete air pipes in the exhaust manifold and ceramic coat
Replace the oil cooler
Replace all hard Brake and fuel lines
Convert to 535i air con lines and bracket
The list goes on and on but i think ill take a break for now :)
On 12/06/2017 at 2:36 PM, kobayashi said:
You certainly need a fair bit of patience with these cars. I blew up the original engine just after a full repaint and suspension overhaul. You just have to take a deep breath and fix it again. Looks lovely though!
What happened?
2 hours ago, kobayashi said:
Spun a big end at 140k miles. It’s first owner was Frank Sytner and I’m fairly sure he didn’t run it in. Fitted one of the two remaining engines BMW had on the shelf.
Oh dear. Would it not have been cheaper to rebuild the engine? If you don’t mind me asking how much was the engine from BMW? Was it a comple unit block and head?
Expensive but brilliant ! Nothing like a brand new engine.
To do a proper restoration type rebuild would have been almost as expensive and didn’t have BMW’s two year warranty. It was a complete block and head, re used throttle bodies, injectors etc. Everything attached to the engine was either overhauled or replaced. I’ve done around 12k miles on the new engine, runs perfectly. I can’t wait to get it out in the spring.
Dave,  what's the suspension setup on this? Looking to replace the suspension on mine in the near future but seem to be struggling to find options which fit the M5?
Hope you are well, been a while since we spoke. I have 3 weeks off over Christmas so hopefully get time to finish the jacking points by then. Been over a year since I've worked on it.
Edited by Azmontana
